03 Mach 1 carbureted with crank trigger distributor - Mustang Evolution
Old 04-22-2011, 12:50 PM   #1
Phil's Avatar
N/A on Mustang Dyno
424.8 rwhp @ 7100 rpms (7300 rpm run on dyno)
347.3 rwt @ 5208 rpms
This was at 27 degree initial timing, Ironically, we made more hp as we lowered timing vs increasing?? No detonation at all up to 34 degrees on Sunoco GT Plus 104 unleaded. This more then likely being the shape of cylinder chambers with the custom domed JE pistons. The lesser timing seems to be where the optimum quench is.
Next dyno session we will are installing a Pro Systems highly modified 650 carb that flows 950 cfm..lean the air/fuel slightly, remove the Mac Pro chamber pipe & pro dump hooker mufflers. Install outlaw mufflers straight off the collectors.
The last run of the night, one of the alternator coolant crossover bolt head broke off..?? So we ended the evening.
Phil
03 Mach 1 carbed with crank trigger distributor
http://www.prbmachining-absdeletemanifolds.com/
Phil is offline   Reply With Quote
Old 04-22-2011, 01:40 PM   #2
stampde's Avatar
Re: 03 Mach 1 carbureted with crank trigger distributor
NICE !!!
2011 GT Auto
Old 04-22-2011, 06:24 PM   #3
Phil's Avatar
Thanks!
Phil
Old 04-23-2011, 07:08 AM   #4
gixxer007's Avatar
Real nice would love to see more pictures and details if you have them.
gixxer007 is offline   Reply With Quote
Old 04-23-2011, 08:09 AM   #5
Phil's Avatar
Here are some pics.
ID:	26307   Click image for larger version
ID:	26309   Click image for larger version
ID:	26311   Click image for larger version
Phil
Old 04-23-2011, 10:32 AM   #6
stampde's Avatar
that car has to be a BEAST !!! LOOKS Great Dude !!!! nice job on everything
2011 GT Auto
Old 04-23-2011, 10:33 AM   #7
Las0mbra's Avatar
Holy ****! That looks amazing!
Old 04-23-2011, 11:21 AM   #8
Phil's Avatar
Thanks guys! Here is a vid of the dual stainless steerl purge, the bottles were low.
Phil
Old 04-23-2011, 11:29 AM   #9
Phil's Avatar
Couple vids from a few months ago when we fired the motor up for the first time. Open headers!
Next N/A dyno session I will be pulling the exhaust system off and dyno with flowmaster outlaw shorty mufflers off of the header collectors. Will be installing a modified Pro Systems 650 carb that came off of a 650+hp 316ci 9500 rpm street warrior 90 GT. Should see another 15+ rwhp around 7200-7300 rpms. Which means we pull the motor to about 7450 on the dyno. We were pulling it to 7250 rpms in the vid I posted.
Then start testing the small shot of nitrous and eventually my goal is to be at 250 shot this summer.
Phil
Old 04-23-2011, 11:41 AM   #10
gixxer007's Avatar
Nice toy you have their for sure.
Old 04-23-2011, 05:10 PM   #11
Phil's Avatar
Thank you!
Phil
Old 04-25-2011, 09:39 PM   #12
Phil's Avatar
Just finished up with Patrick of Pro Systems Racing Carbs. I just ordered the Pro series XC with annular booster style, like the dominators. This carb will be good with up to a 300+ shot. The cfm will be around 880 according to Patrick with all the specs he has on my motor. Should be worth about another 15 rwhp N/A.
Phil
Old 04-25-2011, 10:00 PM   #13
Las0mbra's Avatar
What kind of shot are you running now? How much do you think the block can handle?
Old 04-25-2011, 10:31 PM   #14
Phil's Avatar
Back in 2007 I was running a 175 NX shot on the factory long block motor, running High 10's. 10.73 @ 128mph being my best. I'm planning on 250 shot with this motor. Next dyno session we will start with a small shot to test the system..
The block can handle 800 hp..
Phil
Old 04-25-2011, 10:38 PM   #15
Las0mbra's Avatar
Nice! Can't wait to hear more about that. Sounds like such a sick car. Where are you located anyways?
Old 04-25-2011, 11:18 PM   #16
Phil's Avatar
Thanks! I'm about 35 miles from Summit Motorsports Park in Norwalk, Ohio. The track use to be called Norwalk Raceway Park.
Phil
Old 04-26-2011, 01:56 PM   #17
Phil's Avatar
Vid of the dual stainless steel purge. The botles were low on nitrous.
Phil
Old 05-09-2011, 11:24 PM   #18
Phil's Avatar
Just received the new Pro Systems carb today!
ID:	26737   Click image for larger version
Phil
Old 05-09-2011, 11:28 PM   #19
This is the first time I read this thread. Goddamn this is impressive man. Really nice.
Alscobra is offline   Reply With Quote
Old 05-10-2011, 12:05 AM   #20
Phil's Avatar
Thanks!
Phil
Old 05-10-2011, 03:33 AM   #21
Looks expensive
Dj77 is offline   Reply With Quote
Old 05-10-2011, 08:59 AM   #22
Phil's Avatar
Originally Posted by Dj77 View Post
Looks expensive
$790 + $16 shipping/insurance.. Not bad for a custom built & wet flow race carb based on your specific motor specs..
Phil
Old 05-14-2011, 08:30 PM   #23
Phil's Avatar
Some new pics of the Mach:
ID:	26895   Click image for larger version
Phil
Old 05-14-2011, 09:15 PM   #24
98StangKid's Avatar
Man.... That is freakin' sick. I want one. Haha.
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 05-18-2011, 02:51 PM   #25
Phil's Avatar
Thanks! I'm hoping very soon, the nitrous will be next..!!
Phil
Old 05-18-2011, 07:51 PM   #26
1ijack's Avatar
Send a message via Yahoo to 1ijack
That is wicked looking. Nice.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 05-19-2011, 07:30 PM   #27
Phil's Avatar
Thanks!
Phil
Old 06-02-2011, 09:07 PM   #28
Region: Arkansas
Looks nice! Gotta wheel that thing out though and bring that paint back to life!
HIS: "Night-Mare": 2012 Mustang GT/CS, Black on Black, MT, 3.73 Gears, HID's, Security/Comfort/Electronics Packages. #2 of ????
HERS: "Blue Steel": 2012 Mustang V6, Kona Blue, AT.
Gconn007 is offline   Reply With Quote
Old 06-02-2011, 09:09 PM   #29
Region: Arkansas
Just noticed exactly how raised that hood is. Sitting straight up your going to look like your ghetto cruisin. Does the car have barber shop seat in there to pump up until you can see over it?
Nice numbers though! Im sure it gets up and goes real nice
Old 06-03-2011, 03:23 AM   #30
LSUstang's Avatar
Send a message via AIM to LSUstang
Love it! Welcome to the site!
-2004 Mach 1 "Natasha"- JL Audio W6 w/ custom box, 8000K HIDs, Sequential signals, StangHi tune, Borla Stingers with catted X, deck lid & lower valence, C&L intake package, H&R Super Sports
-2001 White Vert V6- Sold
LSUstang is offline   Reply With Quote
Old 06-07-2011, 03:24 PM   #31
Phil's Avatar
Thanks!!
Phil
Old 06-07-2011, 04:58 PM   #32
WildBill's Avatar
DAMMIT PHIL!!!!!!!!!!!!
When are you hitting the track?.........CHICKEN?
WildBill is offline   Reply With Quote
Old 06-08-2011, 09:16 AM   #33
Phil's Avatar
Wild Bill, how ya doing??? Your right, I am chicken I just got it back Saturday. Drove it 37 mi home from Jeff's shop. Took it out the last 3 days to a empty industrial parkway, practicing shifting at 7800 rpms 2nd & 3rd on the face plated trans, what a rush!! Last night I changed out the BR30 break in oil.
When I get back from vacation June 20th, I plan a trip to the track. Having some issues with the nitrous.
Phil
Old 06-08-2011, 09:32 AM   #34
stampde's Avatar
Bill I think he's scared of it , lol
2011 GT Auto
Old 06-08-2011, 10:35 AM   #35
Phil's Avatar
LOL, 3 yrs ago I was running 10.80's-10.70's on the factory motor with 175 shot, with a minor pucker... Now it's a new creature, dam right I'll be nervous first time going down the track It's quuicker now N/A (and lighter) then it was on nitrous 3 yrs ago. And soon, a 250 shot!
The motor wants to hit 8000 rpms in 1st & 2nd like nothing to it with the drag exhaust on.. I have the rev limiter set at 7800 rpms for now and bounced it in 1st & 2nd yesterday... I'm very impressed with the trans shifting with ease at these rpms.
Phil
need advice...carbureted or not? katie 1979-1995 Mustang GT 11 02-03-2011 12:28 PM
Best carbureted intake with trick flow heads? SlyFox512 1979-1995 Mustang GT 7 01-23-2011 10:34 AM
lol I love Trigger Happy. Seph The Bar 4 07-21-2007 08:55 AM
Chrono Trigger for Nintendo RARE! SpectorV Mustang Parts for Sale and Wanted 7 03-03-2005 12:26 PM
Distributor Question fordman 1979-1995 Mustang GT 3 07-20-2004 12:57 PM
07:39 PM
