4.6L 2V - What options? - Mustang Evolution
Old 04-23-2011, 09:34 AM   #1
Lastoria24's Avatar
Send a message via Skype™ to Lastoria24
I'm not looking for any detailed answers, but does anyone have a good reference that I could use to see what my options are for my 01 Gt 5spd, drivetrain wise?
I was thinking supercharger originally? But that seems pricey for an engine i probably shouldn't dump any money into. Then im reading a about these new Trickflow heads, but im still skeptical about replacing internals and losing driveability (did it on an F-body and wished i wouldve left it stock).
Say I want to put a Cobra motor in it, supercharged or not, where the heck do I find out what is easily doable and what I should avoid. What I want is more power, and i dont want to lose any drivability. I like no check engine lights, running converters for passing emissions, smooth running/driving, etc... Hence the fact I'm thinking about doing a motor swap, to another "stock" motor.
Dont tell me to sell it and buy another car. Thats not an option, i bought the car from a family member for cheap, and the car is spotless. Plus I want something to mess with when I get some cash.
Any websites, specific people to talk to, etc, would be appreciated. I just need to get my bearings on what kind of undertaking this is.
Lastoria24 is offline   Reply With Quote
Old 04-23-2011, 10:25 AM   #2
ksrumbel's Avatar
Pick up the June issue of 5,0 magazine. It has a good article on engine swaps. They say swapping to a 4v motor isnt too bad. You could also supercharge it with low boost and a safe tune. I don't think you will sacrafice much drivability and you can easily get 350 rwhp and be really safe
ksrumbel is offline   Reply With Quote
Old 04-23-2011, 11:25 AM   #3
Lastoria24's Avatar
Funny story....
Sitting in front of me at work, havent opened it yet, LOL!
Thanks : p
Old 04-23-2011, 12:30 PM   #4
I read the article in 5.0 mag about the trickflow heads/comp cams and they seemed to be a good way togo for solid power (not sure the cost of the heads). I have a 2002gt and have been considering what I might do in the future to increase power without losing drivability. I already have all the basic bolt-ons and don't want a 5k supercharger.
Dj77 is offline   Reply With Quote
Old 05-02-2011, 10:53 PM   #5
Stupidfast5.0's Avatar
Re: 4.6L 2V - What options?
Swap in a 3v. That random valve makes a huge difference!
2011 Mustang GT Premium, M6, Procharged.
Stupidfast5.0 is offline   Reply With Quote
Old 05-02-2011, 11:01 PM   #6
I am very unfamiliar with the 3v engines. Are they in stock form, able to to handle and produce more horsepower than the 2v? Just curious. Thats with some type of forced induction or n2o.
Alscobra is offline   Reply With Quote
Old 05-02-2011, 11:07 PM   #7
Send a message via Skype™ to Texastboneking
i fear the 3vs...
Texastboneking is offline   Reply With Quote
Old 05-03-2011, 08:39 PM   #8
Stang.racr's Avatar
2v>3v anyday
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 05-03-2011, 08:54 PM   #9
Originally Posted by Stang.racr View Post
2v>3v anyday
i fear them because of the spark plug issue they have had. aint worth it. go with 2v or 4v
Old 05-04-2011, 01:15 PM   #10
Stang.racr's Avatar
IMO 4v>2v>lsx>3v lol I NEVER owned one but my buddies. Have lots of problems and are slowish. I didn't believe it when one of them started spraying his car that spark plugs were like 20 a pop
Old 05-04-2011, 01:23 PM   #11
stampde's Avatar
keep the engine you have , upgrade to the trick flow heads, cams ,and intake , you'll make close to 400hp with great driveability and no problems .... its all about the $$$$$$$ what can you spend ...........
2011 GT Auto
Old 05-04-2011, 01:57 PM   #12
Stang.racr's Avatar
^ this
Old 05-04-2011, 09:23 PM   #13
2v is not greater than LSX.
Old 05-04-2011, 09:34 PM   #14
Blacks197's Avatar
I just paid 13 a piece for a colder spark in my 3v for my procharger. They are kind of pricey but they make lots of power with boost!
Blacks197 is offline   Reply With Quote
Old 05-05-2011, 05:49 PM   #15
Stang.racr's Avatar
Damm that's high but well worth it and they are a must. How much boost u gonna make
Old 05-05-2011, 05:53 PM   #16
upton7's Avatar
A lot of people don't know that all 2v 3v and 4v heads will fit the block you have.
Old 05-05-2011, 06:01 PM   #17
Stang.racr's Avatar
Heard that's easier said than done and is alot of work that's why most people don't just switch from 2 valve heads to four. Iv never met anybody that has did that transformation
Old 05-05-2011, 06:06 PM   #18
Proof?
Old 05-05-2011, 08:29 PM   #19
Blacks197's Avatar
I haven't put a boost gauge on it yet but it's supposed to be 10 psi
Old 05-05-2011, 11:06 PM   #20
upton7's Avatar
Oh newbies lol. You should have joined a the site a couple years ago.
Old 05-06-2011, 12:07 AM   #21
Oh newbies lol. You should have joined a the site a couple years ago... texastboneking is the only on right here.
thats right!
lol jk
Old 05-06-2011, 01:15 PM   #22
upton7's Avatar
lol me too it definatly isn't just put together n drop in but is not that difficult my only problem is that I have to make an intake manifold for mine.
Old 05-08-2011, 05:22 PM   #23
Stang.racr's Avatar
Hmm box and twin turbos?
Old 05-09-2011, 07:17 AM   #24
Titus Wadicus
svtlx's Avatar
manufacturing parts can be a challenge for some..
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
options on a new gt Cdbformula General Mustang Discussion 0 09-27-2009 06:14 PM
Blower options.. MonteCitan 1979-1995 Mustang GT 9 01-24-2009 08:24 AM
Exhaust options wvstang5.0ho 1979-1995 Mustang GT 18 07-13-2008 10:48 PM
exhaust options.... help!! sledgehammer Pre-2005 V6 Mustang 24 05-31-2008 01:36 PM
supercharger options sledgehammer Pre-2005 V6 Mustang 29 11-28-2007 09:17 AM
04:26 AM
