just want to double check myself - Mustang Evolution
Old 05-12-2011, 09:18 PM   #1
tigercrazy718's Avatar
so i was looking at buying the J&M LCA's that are on sale at AM here:
http://www.americanmuscle.com/2005-p...ling-arms.html
but after doing some research, it seems like these arent the right thing for me. if I understand this correctly, I would really need adjustable LCAs along with a relocation bracket since hopefully very soon my car will be lowered with steeda ultralights and koni yellows. so what i really should be looking at are these:
http://www.americanmuscle.com/extrem...trol-arms.html
and also any other suggestions on other brands are welcome. thanks guys!
2008 V6
204 RWHP
If you wreck and kill yourself trying to jerk off on the way to her house I will put it all over the internet.
tigercrazy718 is offline   Reply With Quote
Old 05-13-2011, 03:42 PM   #2
Titus Wadicus
svtlx's Avatar
Re: just want to double check myself
you dont need adjustables.... the plain lca's are fine.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 05-13-2011, 03:52 PM   #3
ok cool thats what someone on another forum said too. thanks
2008 V6
204 RWHP
where can i get a double deck wing 96mustangv8 1996-2004 Mustang GT 2 05-11-2011 06:59 AM
Double shoot, 03 Cobra vert and my GT/SS CutterWolf 2005-2010 Mustang GT 14 04-15-2011 09:10 PM
Double Cat System Mustangbobby Pre-2005 V6 Mustang 5 09-02-2008 04:24 PM
Who else pulls double duty on 3.8Mustang.com?? 02Stang The Bar 23 09-06-2004 01:12 AM
01:07 AM
