so much questions. - Mustang Evolution
Old 05-15-2011, 12:51 AM   #1
98gtdriver's Avatar
so much questions.
I want to do pi swap for my 98 mustang gt auto. What do I need I think ill get the intake manifold off am but what heads should I get and cams? I bought the fx3 tuner should be here soon... also should I get st headers or lt headrrs?
-Eric
98gtdriver is offline   Reply With Quote
Old 05-15-2011, 07:29 AM   #2
onesickstang01's Avatar
You could just get stock 99/04 heads with the stock cams and pick up a lot of power. There are write ups all over the internet. Try to get romeo heads if you can (01-04). If you want an aftermarket cam dont go bigger than a stage two. There are tons of choices for these as well. U do need the PI intake for sure. The american muscle one is good as it fits just like oem piece. Do not get the one from advance auto parts
onesickstang01 is offline   Reply With Quote
Old 05-15-2011, 08:59 AM   #3
98gtdriver's Avatar
Ok. So the im on am is good or should that come off the 01-04 stang? Where can I find heads? Or do i get those from the mustang too?
-Eric
Old 05-15-2011, 10:44 AM   #4
Intake from AM is good. Heads would either need to be from a 99-04 mustang 2v or aftermarket heads designed for that motor. More than likely stock heads are all that you will need. Also if u can find used heads in you area you will need valve covers as well. There are two style of head used on 99-04 gts. Romeo and windsor. Romeo are better and have an 11 bolt valve cover. Windsors have 13 i believe. Try to get the romeos if possible. The romeo cam gears are bolted on also which is good because the windsors are pressed on so you cant degree them. In my area we have several places that specialize in rebuilding cyclinder heads and you can pick a set up for 300-600 depending on the head. Thats if you can find some on craigslist or a junk yard.
Old 05-15-2011, 08:25 PM   #5
98gtdriver's Avatar
Im new to this.. so would I need to get new cyclinders too? How do you tell the differnce between romeo and windsor?
-Eric
Old 05-16-2011, 05:29 AM   #6
No the block stays the same. Windsor heads have 13 Bolt valve covers and romeo have 11. Also they stopped putting windsor heads on mustangs in 01 so find heads that are mid 01-04 with 11 bolt valve covers
Old 05-16-2011, 07:23 PM   #7
98gtdriver's Avatar
Oh gotcha. I am wanting to do this before summer so im trying to gather info. Do shorty headers give you better air flow than the nasty stock ones?
-Eric
Old 05-17-2011, 10:28 AM   #8
StangSims39's Avatar
Re: so much questions.
i have a good experience with the shortys, a lot of people will say its not worth the money, but if your not going to be drag racing where every bit of hp and torque then go shorties, i noticed a great differnece with the BBK Tuned shorties, both sound and performance wise, nothing too drastic but enough to feel the difference.
StangSims39 is offline   Reply With Quote
Old 05-17-2011, 11:01 AM   #9
98gtdriver's Avatar
Alright inean anythinghas to be better than. Stock lol .. the tuned ones will bolt right on right?
-Eric
Old 05-17-2011, 11:06 AM   #10
Yeah it's a ***** to install bit worth it
Old 05-17-2011, 11:09 AM   #11
98gtdriver's Avatar
What does that entail
-Eric
Old 05-17-2011, 12:33 PM   #12
Took my mechanic 6 hours it's very tight removed wheels jacked the engine up it's very time consuming the best way which I found after is to drop the k member then it's all open
Old 05-19-2011, 09:30 AM   #13
98gtdriver's Avatar
So is it easier to have installed long tubes?
-Eric
Old 05-19-2011, 09:49 AM   #14
I think they are actually from what I heard could be mistaken tho
Old 05-20-2011, 10:34 AM   #15
98gtdriver's Avatar
Well im running stck h pipe should I replace that if I installed headers ? Does it make that big of difference?
-Eric
Old 05-20-2011, 10:35 AM   #16
98gtdriver's Avatar
I mean does the h pipe make that big of difference?
-Eric
Old 05-20-2011, 11:04 AM   #17
Yeah u have to replace the midpipe if u go lts
Old 05-20-2011, 01:49 PM   #18
98gtdriver's Avatar
Alright alot to do... what would I replace them with?
-Eric
I've got some questions about my 68 Sixty8 Coupe Classic Mustangs 1 11-12-2008 07:02 PM
Questions. DVII 2005-2010 Mustang GT 34 01-02-2008 06:02 PM
Questions cms09071987 Pre-2005 V6 Mustang 14 06-26-2005 12:28 PM
Questions DMAC Pre-2005 V6 Mustang 5 08-30-2004 10:19 PM
gt take-off questions blk2kconvstang Pre-2005 V6 Mustang 7 03-22-2004 08:02 AM
08:07 PM
