swing arm squeak? - Mustang Evolution
Old 05-29-2011, 11:51 AM   #1
austinknoll's Avatar
swing arm squeak?
I'm pretty sure it's my swing arm but whenever I turn I have an annoying high pitched squeak coming from the right side. I have no clue what to do. Or what the problem is. Anyone help please
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 05-30-2011, 08:20 AM   #2
Re: swing arm squeak?
Does it squeek when you are parked and just turn the wheel? It could be your steering rack bushings or the steering rack mounts rubbing on the k-member.
Old 05-30-2011, 09:06 PM   #3
It squeaks whenever I move the steering wheel. I really want it fixed
65 Mustang coupe
Old 05-31-2011, 07:14 AM   #4
steering rack bushings perhaps? that or the sway bar~
Old 05-31-2011, 09:51 PM   #5
Hmm maybe when I get my job, I might go to a mechanic or even ford dealership ( I know a guy there) to get it fixed of my dad and I cant
65 Mustang coupe
Old 06-01-2011, 07:21 AM   #6
spray some WD-40 on the steering rack bushings see if it gets better, does it go away when its raining hard?
Old 06-01-2011, 04:35 PM   #7
I'll try that thanks but I'm not sure because here in san Diego it never really rains that much
65 Mustang coupe
Old 06-03-2011, 09:14 PM   #8
I found where the squeak is coming from and I'm pretty sure it's the lower a arm connects to the shock. I put some lubricant on it and it sorta fixed it. I put more on it today so we will see how it works out if not I'll try and get it fixed at a dealer or mechanic cause I dot have a spring or shock condenser or whatever it's called
65 Mustang coupe
Old 06-03-2011, 09:35 PM   #9
jhagan1980's Avatar
Use a floor jack to compress the strut by raising the a-arm. This will allow you to unbolt the strut safely.
jhagan1980 is offline   Reply With Quote
Squeak Snapple750 1996-2004 Mustang GT 7 04-08-2011 10:50 AM
A/C squeak Foxone General Mustang Discussion 9 11-22-2009 02:01 PM
How not to use a rope swing PureVenom The Bar 10 09-25-2004 04:23 PM
10:29 PM
