Replacing my clutch... - Mustang Evolution
Old 06-08-2011, 08:18 PM   #1
TaylorF25's Avatar
I have an 03 v6 3.8L, I have to replace the clutch due to either the pressure plate or a bearing. I was quoted around $350 just for labor and to remachine my flywheel. I'm trying to get out for as cheap as I can with labor. Any ideas? I've done work on the car by myself in the past but I've never messed with the tranny. Any ideas or comments please let me know. Thanks
TaylorF25 is offline   Reply With Quote
Old 06-08-2011, 09:21 PM   #2
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Replacing my clutch...
If you're not comfortable, I wouldn't do it. Realistically, pulling and reinstalling a manual trans in a mustang is a cake walk as long as yourself, and the friend that helps you, are substantially sized to do some picking up or pushing if needed......though it may not be needed.
$350 to R&R the trans and resurface the flywheel sounds about right. I'm guessing the R&R w/ clutch and flywheel R&R is rated at 3-5 hours, and there will be a fee to resurface the flywheel.
If you do this, go ahead and replace the clutch if it hasn't been replaced in awhile. A new clutch set should include a throw out bearing and pilot bearing.
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-09-2011, 04:41 AM   #3
TaylorF25's Avatar
Sounds good thanks
Old 06-09-2011, 06:01 AM   #4
TaylorF25's Avatar
My only other question is what's the best way for me to learn how to do the replace?
Old 06-09-2011, 07:26 AM   #5
You have a T-5 trans, rather easy to work on. You can take the trans out without removing the bell housing unlike GT guys lol. You could do it yourself if you wanted~ but you HAVE TO MAKE SURE you do it all correct and you will need a few tools here and there.
You want to replace the pilot bearing, replace/resurface the flyweel (depending on need), inspect the input shaft for play must be in tolerance else fix it, inspect the sleeve the throwout slides on replace if ANY signs of wear (replace with steel honestly), replace throwout bearing with HD version from Ford (those little bastards are a nightmare... love to tick and squeek if not done right might can even pack more greese in it not sure)
replace fluid of course (cheap why not!) then install with new clutch. I would go back with OEM they hold more power than most will ever need and are good.
A shop would be good to do it IF they are good with warranty and if anything is not right etc... the issue is clutches sometimes chatter and such or the throwout goes bad quick... shops LOVE to blame it on the owner or that it needs a break in period... then when its broken in and still does it... its got to many miles to fix ha...
Old 06-09-2011, 12:06 PM   #6
TaylorF25's Avatar
I tryed to find someone to help me that has done it before but its looking like ill have to take it to a shop and bite the labor. Just a little rough with the money but it needs to be done.
Old 06-09-2011, 05:29 PM   #7
If you have any friends who know how to pull/put the trans in a foxbody......they can walk you through this
-Will
Waffles
Replacing a RIM CamperD Pre-2005 V6 Mustang 10 01-21-2011 11:04 AM
Help Replacing Mirror Buck Pre-2005 V6 Mustang 6 09-23-2008 11:22 AM
What to do when replacing Odometer? fast64 General Car Discussion 5 01-17-2008 08:52 AM
Need help replacing thermostat floridamba Pre-2005 V6 Mustang 1 04-01-2007 06:30 PM
replacing a mirror mexor Mustang Audio & Video 14 03-07-2004 07:48 PM
12:36 AM
