Spark blow out - Mustang Evolution
Old 06-14-2011, 12:00 PM   #1
Spark blow out
Hey I have a 99 gt super charged dyno tuned recently at 5000 rpms at 5 psi it starts bucking basically 2 and 3 gear It won't let it see full boost which is 9.7 any ideas.
chenz48 is offline   Reply With Quote
Old 06-14-2011, 02:31 PM   #2
Re: Spark blow out
what plugs and what range, have you pulled the plugs to look for signs of detonation or anything out of the ordinary?
Old 06-14-2011, 02:45 PM   #3
I'm using Ngk tr6s.. I have not pulled them yet what should I look for? Nothing out of the ordinary it runs great other than this issue.
Old 06-14-2011, 02:55 PM   #4
Re: Spark blow out
check the gap, not sure what it should be but it shouldnt be like 50 or anything I dont think.
check the base for dimples or messed up areas.
Old 06-14-2011, 03:08 PM   #5
stampde's Avatar
Re: Spark blow out
S/C You should close the gap up , probably like 028
2011 GT Auto
Old 06-14-2011, 05:43 PM   #6
Ok I'll check it out let you know how I make out thanks
Old 06-14-2011, 06:39 PM   #7
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Spark blow out
Why are you assuming the lack of full boost is spark based?
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-15-2011, 06:54 AM   #8
-Will
Because the motor it self what achieve the rpms it needs to hit full boost. Centri superchargers full boost is achieved all up top
Old 06-15-2011, 06:58 AM   #9
Re: Spark blow out
-Will
I was taking it as he couldnt get up in the rpms (to make boost) due to spark blow out/miss so its not missing boost its he cant get to the rpm level to make the boost under load.
Old 06-15-2011, 07:03 AM   #10
Yes correct
Old 06-15-2011, 07:14 AM   #11
Re: Spark blow out
check all connections for leaks and such as well and as said clean your MAF sensor
Old 06-15-2011, 07:25 AM   #12
Can you be a little more specific on what connections I should check.
Old 06-15-2011, 08:54 AM   #13
Re: Spark blow out
hoses on intake are all clamped down, no leaks or pipes not connected, maf sensor all sensor connections plugged up, and check any vacuum lines that might be disconnected.
Old 06-15-2011, 09:40 AM   #14
wereKEV's Avatar
Re: Spark blow out
Don't take any chances check all connections.
wereKEV is offline   Reply With Quote
Old 06-15-2011, 06:51 PM   #15
Ok i will check it out this weekend I will let you guys know what's up. Thanks for the help!
Old 06-15-2011, 08:36 PM   #16
Re: Spark blow out
What is your setup? All mods/details....
What plugs do you have and what are they gapped to?
-Will
Waffles
Old 06-15-2011, 09:01 PM   #17
Vortech v2sq intercooler, 42 lb bosch injectors. Ford focus act fuel pump 255 lph, msd coil packs, 90 mm MAF, Ngk tr6 sparks.. I don't remember what I gapped them at it was a year ago.
Old 06-15-2011, 09:06 PM   #18
Re: Spark blow out
Ah, get some fresh TR6's and gap them down to about .035-.040
See how that works before you do anything else.
-Will
Waffles
Old 06-16-2011, 06:36 AM   #19
Lol that's it I'm gonna start some where easy. Thanks I appreciate it, l will keep you updated.
Old 06-16-2011, 11:34 PM   #20
Re: Spark blow out
That's always the best approach! Let us know how it goes!
-Will
Waffles
Old 06-17-2011, 07:09 PM   #21
onesickstang01's Avatar
Yes plugs need to be gapped around .035. Also make sure you dont drop fu pressure as well. Im running a similar setup but a bit more boost and aftercooled and i needed the boostapump even after the 255
onesickstang01 is offline   Reply With Quote
Old 06-21-2011, 06:08 AM   #22
All set guys changed the plugs gapped at .033 and the car runs mint. I can hit the rev limiter no problem. Thanks!
What happens when you blow out a spark plug. drusmith General Mustang Discussion 10 04-01-2011 12:26 PM
Problem with gt40p spark plugs want some good spark plugs but most wont fit?? Justbust1n 1979-1995 Mustang GT 6 03-01-2011 03:20 PM
Blow by blow racings 2011 GT DDTCM 2011-2014 Mustang GT 7 11-11-2010 07:59 AM
Tire blow out Scut95 The Bar 7 08-25-2008 11:12 PM
Blow off valve drwang Pre-2005 V6 Mustang 32 10-13-2005 05:35 AM
01:58 AM
