Driver Door Ajar Message - Mustang Evolution
Old 06-15-2011, 07:24 PM   #1
So my display all of a sudden is telling me that the driver door is still ajar when I know the door is closed. I have LSD lambo door hinges installed on it, not sure if the sensor is in the hinge or the latch assembly. The weird thing is the windows go up and down when the door opens and closes which would lead me to believe that the switch is still working fine.
I have been doing a little research and some people have said to spray wd40 in the latch assembly so that's what I'm going to try. Any other suggestions would be so grateful. And if someone can tell me where exactly the sensor may be that would be awesome because I still have yet to find that information out.
Thank you!!
Badassnut84 is offline   Reply With Quote
Old 06-15-2011, 07:36 PM   #2
Re: Driver Door Ajar Message
The WD40 works.....used it many times....
2008Shelby is offline   Reply With Quote
Old 06-15-2011, 07:53 PM   #3
I just sprayed the living bejesus out of the latch and still no fix
Old 06-22-2011, 10:12 AM   #4
So I installed a new latch assembly and door ajar switch and the message still appears. What could it possibly be????
Old 06-22-2011, 11:01 AM   #5
Send a message via Skype™ to Texastboneking
What style door ajar switch do you have? Is it the push button style?
Texastboneking is offline   Reply With Quote
Old 06-22-2011, 12:48 PM   #6
It is like a push button. Unless I have it installed in the latch assembly wrong, I have no idea why I'm having such a hard time.
Old 06-22-2011, 12:49 PM   #7
Probably installed wrong...
Old 06-22-2011, 02:48 PM   #8
If anyone can provide instructions on how I can completely remove the door latch assembly? I got everything off of it except for the cable leading from the exterior door handle.
Old 06-22-2011, 03:01 PM   #9
Not gonna be sure on a Lamborghini setup...
Old 06-22-2011, 03:52 PM   #10
Just got done installing a different door ajar switch, thinking the other one is defective, and still no go
Old 06-22-2011, 04:03 PM   #11
Sure it's the driver door?
Old 06-22-2011, 04:28 PM   #12
That's what the display under the speedo is telling me. Do you think a wire got crossed, in the lambo door install, and it could be the passenger door or trunk ajar switch?
Old 06-22-2011, 04:29 PM   #13
No tellin man
Old 06-22-2011, 04:29 PM   #14
If you unplug the switch the door ajar light should go off
Old 06-25-2011, 02:12 PM   #15
HoeHoe's Avatar
I would disconnect the switch and check continuity to ground sound like you have a short to ground
HoeHoe is offline   Reply With Quote
Old 07-02-2011, 09:30 AM   #16
Finally got the car back from the dealership yesterday. It ended up being a frayed wire under the passenger side dash. Some wire that connects to a control box. I would've never been able to figure that one out on my own.
Want To Buy: Driver Side Door tigerfan2771 Mustang Parts for Sale and Wanted 0 03-04-2010 08:31 PM
Replacing Driver Side Door tigerfan2771 Mustang Audio & Video 4 03-04-2010 05:14 PM
Message from Osama Ken The Bar 12 10-27-2006 10:30 AM
Message From NJ Black95GT Regional Mustang Discussion 1 02-05-2004 01:18 PM
message from the little one: Rellik The Bar 15 10-02-2003 08:30 PM
07:10 AM
