Rust - normal? - Mustang Evolution
Old 06-19-2011, 12:09 PM   #1
bluefirstgt's Avatar
Rust - normal?
I recently purchased a used 06 GT. My father always said "by a quality product, take care of it, and it can last you a lifetime."
Most of the vehicle looks in great condition with the exception of a few areas.
The exhaust system is an addition and I notice rust along the welds (any suggestions / concerns?), the rear drive of the vehicle also has rust (suggestions?).
I would like to get my GT into show "clean" condition eventually and I'm taking a guess in saying "rust should not be anywhere." Any suggestions on how to clean, restore, or replace?
ID:	28050   Click image for larger version
ID:	28052   Click image for larger version
bluefirstgt is offline   Reply With Quote
Old 06-19-2011, 12:59 PM   #2
Las0mbra's Avatar
Umm, some parts get a little surface just and it's not a problem. And if anybody disagrees or has heard otherwise correct me when I say, some parts are made to get a little bit of rust to almost protect it a little. But who knows... For a show car though, idk...
Old 06-19-2011, 03:02 PM   #3
junoS197Bl08's Avatar
Re: Rust - normal?
yep ur correct, some parts such as the rear axle, and your stock headers will appear rusted, but this is only surface rust and is no big deal. I don't know about those after-market exhaust pieces though. If I was you I would maybe clean of the rust on the exhaust hangers and such and then hit it with some Rustoleum that can take the heat range of an exhaust pipe. That part (exhaust) might possibly be able to rust and cause no issues, but I don't think it is supposed. Somebody else might know tho.
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 06-19-2011, 05:51 PM   #4
Re: Rust - normal?
I agree that rust in some areas is normal HOWEVER I know in the year '06 Ford has extra rust inclined parts underneath the trucks....more so than usual...I have no idea bout mustangs that year though...
2008Shelby is offline   Reply With Quote
Old 06-19-2011, 09:04 PM   #5
mustangchassy's Avatar
I have an 07...the rust is not that bad...actually not even close. You also gotta think if you just got it. Who knows how it was taken care of before u. But I do have some rust..It's expected..it is the underneath of a car lol
2013 GT Premium: 15% Tint/Roush Axleback/Gloss Black 5.0 Badges/2007 GT Premium (SOLD)
mustangchassy is offline   Reply With Quote
Old 06-19-2011, 09:47 PM   #6
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
Re: Rust - normal?
I know they make some spray paint that converts small, surface rust into black, non-rust. It's worth a shot. I don't know how it works
-Will
Waffles
Knight F Mohawk is offline   Reply With Quote
Old 06-19-2011, 10:35 PM   #7
Blogger
99ford's Avatar
Re: Rust - normal?
It looks pretty normal. My rear axle is that way maybe a tad worse.
Old 06-20-2011, 06:46 AM   #8
Tib
Tib's Avatar
Re: Rust - normal?
normal
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 06-20-2011, 07:16 AM   #9
Re: Rust - normal?
yea fix the exhaust with good quality parts/setup for sure
those rust spots are normal on all GT's, only thing you could do is sand all the rust off and powdercoat it or paint the areas etc but its normal
Old 06-20-2011, 07:41 AM   #10
Good to know that the majority feels this is normal. It's easy enough to sand the differential, but some of the areas will most likely need to be removed for prep / paint. Since it's normal, I will keep an eye on it. Any spray type protectants that can be used to slow this down? What # sand paper would you use "250"?
Anyone know of a rust primer and paint that can be used for the exhaust that resists heat? (Until I can afford to replace the exhaust system). So no one has heard of "Spin Tech" exhaust systems?
Last question (for today); what's the best product to clean/detail the engine and what should I be concerned about when cleaning the engine?
I watched "OverHauling" over the weekend and am motivated to get the Mustang cleaned up!
Old 06-20-2011, 07:44 AM   #11
Re: Rust - normal?
they make a coating that can be put right on top of rust and kills it you can look into that, cant remember its name though
Old 06-20-2011, 08:59 AM   #12
Greg687's Avatar
Region: New Mexico
Re: Rust - normal?
Look for rust converter. It will end up black, so you might plan on painting parts to match. I do not think it will worn on the exhaust though, for there you will need high-temp paint.
Greg687 is offline   Reply With Quote
Old 06-20-2011, 09:20 AM   #13
Re: Rust - normal?
yea but the exhaust pipe should be stainless so it wont rust (well OEM is)
Old 06-20-2011, 09:24 AM   #14
Greg687's Avatar
Region: New Mexico
Re: Rust - normal?
He said the exhaust was aftermarket. Many times welds will rust, which is what his looks like. Shooting that with some silver header paint would make it look better and last longer.
Old 06-20-2011, 09:26 AM   #15
stampde's Avatar
Re: Rust - normal?
they never paint the rear axles from the factory ,they leave them raw cast and they rust ..
The first month I had the Mach 1 I removed the rear ,painted it with etching primer ,and then gave it a good coat of black engine enamel , they re installed it , I also painted the drive shaft , they both still look great
2011 GT Auto
Old 06-20-2011, 12:21 PM   #16
Rust converter and silver header paint are great suggestions. I will start with those.
I will place new exhaust (stainless) as well as painting the bare parts on my list of upgrades.
Shifter lights and trunk rust? Patrick Mustang Audio & Video 0 02-15-2011 01:14 PM
rust 95blackgt 1979-1995 Mustang GT 2 03-27-2008 02:59 PM
rust prevention OXstang11 Mustang Audio & Video 10 11-24-2005 07:11 PM
Rust spots on CAI. Rellik Pre-2005 V6 Mustang 5 12-14-2003 12:34 PM
RUST~~~~!!!! ASSEMbler Pre-2005 V6 Mustang 7 12-13-2003 10:41 PM
02:11 PM
