Rear diff fluid - Mustang Evolution
Old 06-27-2011, 12:44 AM   #1
96 stang's Avatar
Rear diff fluid
Hey guys, so I've been reading up on what rear diff fluid I should use in my 96 gt & I'm getting confused. Some people say I don't need friction modifier if I use full synthetic & others say I do. Is it better to run full synthetic? I've never done this before so if you guys could give me some help it would be greatly apreciated. Thanks
96 stang is offline   Reply With Quote
Old 06-27-2011, 12:45 AM   #2
96 stang's Avatar
& I have 4.10's if it makes a difference
Old 06-27-2011, 01:09 AM   #3
stangkid's Avatar
Re: Rear diff fluid
I would stay away from synthetic and just use regular fluid with friction modifier.
stangkid is offline   Reply With Quote
Old 06-27-2011, 05:32 AM   #4
Send a message via Skype™ to Texastboneking
What brand diff and what brand gears? You probably already have full synthetic in it. Ford uses full synthetic and yes you need the friction modifier
Texastboneking is offline   Reply With Quote
Old 06-27-2011, 09:02 AM   #5
Re: Rear diff fluid
if you have a tlok unit (OEM on GT mustangs) then you need friction modifier. Some comes in the fluid already and some fluids dont have it already. Thats the question you need to answer.
Old 06-27-2011, 10:17 AM   #6
96 stang's Avatar
Well the car had the gears when I bought it. Is there a way I can find out what brand gears is has & what brand the diff is? The previous owner Said the diff was rebuilt not replaced so I'm assuming it's stock but if there's a way I can check I will do that.
Old 06-27-2011, 10:54 AM   #7
Re: Rear diff fluid
its probably oen ford no matter what if it was rebuilt or replaced, gears it will be ok with the oem fluid as well
Old 06-27-2011, 01:34 PM   #8
96 stang's Avatar
Okay cool thanks. & will the local auto part store be able to tell me what kind because my Haynes manual doesn't say
Old 06-27-2011, 02:31 PM   #9
stampde's Avatar
Re: Rear diff fluid
use royal purple it has the friction mod already in it
2011 GT Auto
Old 06-27-2011, 02:33 PM   #10
It ought to for the price lol
Old 06-27-2011, 02:35 PM   #11
stampde's Avatar
Re: Rear diff fluid
You got that right
2011 GT Auto
Old 06-27-2011, 02:53 PM   #12
96 stang's Avatar
It's kind if expensive but I might just go that route. Thanks
Old 06-27-2011, 06:10 PM   #13
kickerofdoom's Avatar
Moble one is good and half the price
What Brake Fluid do you use? 99ford General Mustang Discussion 1 06-27-2011 09:34 AM
03 v6 rear brakes TaylorF25 Pre-2005 V6 Mustang 8 06-25-2011 10:01 PM
05:59 PM
