My 2000GT - Mustang Evolution
Old 07-04-2011, 12:51 PM   #1
My 2000GT
Hello all,
I have a 2000GT which I drive every day, I recently replaced the thermostat and after a couple days I noticed a puddle in the garage. I'm hoping to get some advice on the best way to repair a leaking theromstat housing unit; I believe I cracked it by over tighting . Short of replacing the entire unit; is there a better way? Thank you in advance and any advice is much appreciated.
John
twinzo1 is offline   Reply With Quote
Old 07-04-2011, 08:15 PM   #2
Camo1967Mustang's Avatar
Re: My 2000GT
I would just replace it
I really don't know how you could fix it
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
Old 07-05-2011, 09:18 AM   #3
Titus Wadicus
svtlx's Avatar
Re: My 2000GT
i coated the housing with a layer of jb weld and let it set up over night, when i cracked the t-stat housing in my gf's lexus.... but i would advise just buying a new one.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
08:03 AM
