Engine swap, here we go - Mustang Evolution
Old 07-04-2011, 06:51 PM   #1
Ok, so I bought a 2001 3.8l with high hopes for performance. What an idiot, lol. Come to find out, 3.8l were all show and no go. So, that being said, I want to do an engine swap but I have a few questions. What engine will I be able to swap with with the least amount of mods. I know the tranny and gears are going to have to be changed, but as far as moving motor mounts, I would like to try to avoid that. Any suggestions? I am not going to buy a v8, trade for a v8, or anything like that. I am keeping this car, so lets roll with that. And yes, I know this is about to get expensive.
Mustanglife is offline   Reply With Quote
Old 07-04-2011, 07:06 PM   #2
Jamesgt08's Avatar
I would go for an 03/04 cobra motor and tranny rear end fuel pump.
Jamesgt08 is offline   Reply With Quote
Old 07-04-2011, 07:13 PM   #3
That would require me moving the motor mounts rightm
Old 07-04-2011, 07:18 PM   #4
Send a message via Skype™ to Texastboneking
Nope. Just new k member
Texastboneking is offline   Reply With Quote
Old 07-04-2011, 07:19 PM   #5
Jamesgt08's Avatar
Yea i think you will need a new k-member. But it will be worth it.
Old 07-04-2011, 07:29 PM   #6
Gotcha gotcha. Getting my hands on a cobra motor its gonna be difficult. Really all I need is the block to start. Gonna build the engine outside the car first. Then when its done, drop it in. As for the tranny, any suggestions? Writing harness? ECU? Rear end?
Old 07-04-2011, 07:29 PM   #7
Wiring*
Old 07-04-2011, 07:30 PM   #8
Gearheads engines sells them pretty cheap and they have a 3 year unlimited mile warranty.
Old 07-04-2011, 07:33 PM   #9
Awesome, I will check them out. Would rather buy that way then from a junkyard. Never know what you will get from there anyway
Old 07-04-2011, 07:35 PM   #10
Right. I wanna say a long block for a 01 cobra engine was like 4000. Which is cheap for a cobra. But I could be wrong so check and don't quote me lol
Old 07-04-2011, 07:40 PM   #11
Nice
Old 07-04-2011, 07:56 PM   #12
Found a ford racing boss modular 5.0 engine block for &1209.99 on american muscle. Sound good?
Old 07-04-2011, 07:57 PM   #13
Says everything but pistons will fit this engine from a stock gt 4.6l
Old 07-04-2011, 08:11 PM   #14
So it's a bored 4.6 liter. Are you planning on building an engine???
Old 07-04-2011, 08:15 PM   #15
Yea, thats why all I am looking for is the block. Less parts for me to have to throw away. Besides, at least that way I can make it how I want it from the start. At least that seems more logical to me. I dont see the the point in buying a fully built engine. Theres no pride in that. And I dont see the point in paying the price for a built engine when I am just going to be changing parts for what I want anyway.
Old 07-04-2011, 08:17 PM   #16
Go for a 5.0 build then lol
Old 07-04-2011, 08:18 PM   #17
My next concern would be the chasis. At what point am I going to have to beef it up? Is the v6 chasis the same as a v8 gt/cobra chasis? Am I going to have to change the whole axle or just the gears? What ECU am I going to need? What wiring harness?
Old 07-04-2011, 08:20 PM   #18
Call a tuner for the harness and wiring harness he will have to tune the car to run right so he will know what you need. The unibody is the same for v6 to cobra.
Old 07-05-2011, 09:13 AM   #19
Titus Wadicus
svtlx's Avatar
Re: Engine swap, here we go
i would do a pushrod 5.0 swap... you dont have to change the k-member, just run wut u brought. and if your rock'n a t-5 in your tunnel, you can also keep that. you just have to upgrade to a v8 flywheel. you can use a 94-95 gt harness, and there are sum other wire harness options available. you could even do a explorer 5.0 harness conversion and have yourself a "dis" system and already set-up for returnless fuel.
then you can upgrade the rear end to an 8.8. or just drop in a trac-lok , if your on a budget and dont plan on racing the car (no slicks or dot's). i been runing a 7.5 with 3.45 gears and a frpp trac-lok with for over 5yrs w/450hp and no problems
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-05-2011, 09:16 AM   #20
That sounds good, but I really want a cobra engine. Is it just me, or do they have a unique sound? But your idea sound cheaper since I am on a budget
Old 07-05-2011, 09:26 AM   #21
Good engine. But he will never be able to get it inspected...
Old 07-05-2011, 09:27 AM   #22
Trust me they have a very distinct sound
Old 07-05-2011, 10:40 AM   #23
Titus Wadicus
svtlx's Avatar
well itsa thought.... the cobra conversion is just so fukn pricey imo. if i was gonna do one i would use a crown vic. i saw a guy on youtube wit one. it was freakn crazy watchn a vicky blow by wit the blower whine... now thatsa sleeper...lol.
im getn real close to startn my '97 3.8 to 5.0 conversion... lemme know if i can answer any questions for u.
Old 07-05-2011, 10:45 AM   #24
It's pricy and the 5.0 is a great motor. Just gonna be near impossible to get inspected. How do you plan to get yours inspected or do you not need an inspection where you live?
Old 07-05-2011, 10:46 AM   #25
Just had a guy hit me up wanting to sell me his 5.0 motor. Havent seen it yet though. You and I might bee getting to know another pretty well if I get that engine, lol. And I agree. I called AM and was taking about a cobra swap, gonna be hella expensive. Since I dont have the cabbage, lol, I am gonna have to get what I can get, know what I mean?
Old 07-05-2011, 11:26 AM   #26
Titus Wadicus
svtlx's Avatar
there's no inspection in my part of ohio. and when i lived where there was one, i just let it fail 3 times and get an exemption. i got .529 lift, no cats, and 11psi of boost. it's not passing anyones inspection.
Old 07-05-2011, 11:33 AM   #27
Titus Wadicus
svtlx's Avatar
just lemme know.... p.m. me and i will give u my number. there are a few details that u have to know bout if u do a 5.0. also, just bout everything from a fox will transfer to the 94-03.. this will make your swap more affordable. all my suspension, exhaust, fuel pump, and everything else from my 92 coupe bolted right up.
im not a mod motor expert, but i could help a lil bit if u go that route also.
Old 07-05-2011, 11:39 AM   #28
Sounds like a plan
Old 07-05-2011, 11:41 AM   #29
Jamesgt08's Avatar
What part of houston are you from?
Old 07-05-2011, 11:42 AM   #30
Porter
Old 07-05-2011, 11:52 AM   #31
A.K.A. Baby-D!
make sure to post lots of pics and info regarding to the swap. have fun and good luck!
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 07-05-2011, 11:53 AM   #32
Well do, thank you
Old 07-05-2011, 11:53 AM   #33
Will*
Old 07-05-2011, 12:05 PM   #34
Jamesgt08's Avatar
Ur not that far from me. I live near humble. My gf lives in porter.
Old 07-05-2011, 12:05 PM   #35
Right on
v6 swap to cobra will21 Pre-2005 V6 Mustang 43 09-07-2011 04:56 PM
Strange engine swap idea ArmyStang 1996-2004 Mustang GT 25 07-05-2011 10:29 AM
4.2L engine from a 98 3.8L bmabbott Pre-2005 V6 Mustang 11 07-01-2011 09:09 PM
engine swaps will21 Pre-2005 V6 Mustang 4 06-30-2011 09:54 AM
Auto to manual swap Jamesgt08 1996-2004 Mustang GT 6 06-25-2011 01:45 PM
12:50 AM
