engine fitment - Mustang Evolution
Old 07-10-2011, 10:05 PM   #1
98gtdriver's Avatar
engine fitment
Would a 4.6l from a 2009 fit my 98?
-Eric
98gtdriver is offline   Reply With Quote
Old 07-10-2011, 10:18 PM   #2
Jamesgt08's Avatar
Yess it should.
Jamesgt08 is offline   Reply With Quote
Old 07-10-2011, 10:20 PM   #3
Jamesgt08's Avatar
Its the same size block. The heads and intake are the main differences between the two.
Old 07-10-2011, 10:21 PM   #4
98gtdriver's Avatar
Ok but would I need wire harness? And what else for a swap?
-Eric
Old 07-10-2011, 10:25 PM   #5
wc3john's Avatar
I've never owned either but I'm sure you would need a new harness and computer that matches a 3v. maybe motor mounts and headers... But idk really, these are just questions I'd ask
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 07-10-2011, 11:06 PM   #6
Send a message via Skype™ to Texastboneking
Re: engine fitment
new wiring harness and pcm. you will lose a few funcions unless you mod things yourself. like rpm gauge. the clusters are different and you cant use the cluster ot of an 09 cause it wont fit. and honestly if you do the pi and a few other mods. the 09 3v isnt really all that much faster ( for the cost of you trying to swap one in) you would have better luck at trying to drop in a cobra motor. they fit the same and the pcm from one will work in your car just fine.. your gonna spend a great deal of money trying to get that 3v engine in your car
Texastboneking is offline   Reply With Quote
Old 07-10-2011, 11:30 PM   #7
98gtdriver's Avatar
Oh gotcha. Thanks bone. Im just so up ib the air. So head cams intake manifold also long tube headers new throttle body. What would the hp gain be close or in the 300s? With a supercharger?
-Eric
Old 07-11-2011, 06:32 AM   #8
Heads cam intake and a professional tune should get you close.
Add a supercharger and you can get close to 400 maybe a little more
Old 07-11-2011, 07:52 AM   #9
stampde's Avatar
Re: engine fitment
Muscle Mustang just did a 2 valve build up with tfs heads .cams ,and intake and got around 460 NA Hp / pretty stout
2011 GT Auto
Old 07-11-2011, 07:59 AM   #10
That is pretty stout
Old 07-11-2011, 08:00 AM   #11
stampde's Avatar
Re: engine fitment
4.6L Two-Valve Stroker Motor Build - Muscle Mustangs & Fast Fords Magazine
here's the article ....
2011 GT Auto
Old 07-11-2011, 08:06 AM   #12
Verry nice!
Gonna tell my friend about the heads and see if he wants to go for it
Old 07-11-2011, 08:12 AM   #13
stampde's Avatar
Re: engine fitment
Heads are where the power's at !!!
2011 GT Auto
Old 07-11-2011, 08:39 AM   #14
Titus Wadicus
svtlx's Avatar
Re: engine fitment
i read it, and omg, thatsa awsome set-up. but is it cheaper to build that or drop on centri with a micro pulley and a giant intercooler?
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 07-11-2011, 09:57 AM   #15
98gtdriver's Avatar
Yeah that's awesome but howw does non pi engine have 260 from the start? I want to bore mine out im going to my dads buddies shop tuesday swei g what they can di and for how much
-Eric
Old 07-12-2011, 05:46 PM   #16
Las0mbra's Avatar
It says in the article a pi swap was done before the major engine work
Engine Swap BlackBeauty01 1996-2004 Mustang GT 5 07-07-2011 09:15 AM
Engine swap, here we go Mustanglife General Mustang Discussion 65 07-05-2011 08:07 PM
Strange engine swap idea ArmyStang 1996-2004 Mustang GT 25 07-05-2011 10:29 AM
4.2L engine from a 98 3.8L bmabbott Pre-2005 V6 Mustang 11 07-01-2011 09:09 PM
2011 5.0 suspension question - roush trak pak fitment apex32 2011-2014 Mustang GT 1 06-30-2011 05:22 PM
06:35 AM
