Gas - Mustang Evolution
Old 07-17-2011, 10:25 PM   #1
Gas
Is it worth the money fill up premium or mid-grade, or is it fine to fill up with regular. What type of gas do you fill up with?
mickeyp49 is offline   Reply With Quote
Old 07-17-2011, 10:26 PM   #2
Jamesgt08's Avatar
Is your car tuned to premium or midgrade? My car is tuned to premium so i fill up with premium.
Jamesgt08 is offline   Reply With Quote
Old 07-17-2011, 10:35 PM   #3
No I just purchased a 2012 V6 last week so everything is stock as of right now.
Old 07-18-2011, 01:27 AM   #4
Re: Gas
run regular...your car was designed for regular and your computer works best on it...
2008Shelby is offline   Reply With Quote
Old 07-18-2011, 07:11 AM   #5
Re: Gas
if a car is tuned for premium then running it will make it have better performance. Pre 11 Mustang GT's are not tuned for premium so it doesnt do anything to run it, no use. The 2011 GT is designed to run on 87 or premium etc and makes more power when it does.
Having it tuned for premium of course helps.
Old 07-18-2011, 11:35 AM   #6
wereKEV's Avatar
Re: Gas
Your car is made for regular ,I run premium in mine because it is supercharged but your car is a stock v6 it is set up to run regular grade gas.
wereKEV is offline   Reply With Quote
Old 07-18-2011, 11:57 AM   #7
Re: Gas
if you ever have it tuned for premium then you should ONLY run premium just FYI
Old 07-18-2011, 01:19 PM   #8
junoS197Bl08's Avatar
Re: Gas
plus if you just read in the manual it will tell u what gas is the correct octane for ur engine. Different octanes just explode in different ways, the gas is not better just meant for engines tuned to obtain energy more efficiently from these patterns.
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 07-18-2011, 01:21 PM   #9
Tib
Tib's Avatar
Re: Gas
Like stated above run regular unless it's been tuned otherwise. I ran regular in my 98GT for the entire time I had it without issues plus now in my 03 Roush
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 07-18-2011, 01:52 PM   #10
Ok so what are the benefits of having my car tuned to premium.
Old 07-18-2011, 01:59 PM   #11
Re: Gas
more horsepower potentially when you have it tuned for higher octane gas as long as u put in the same octane as u tune it for. Also some people can get pinning when using lower octane fuel and using a higher octane fuel could help with that also.
Old 07-18-2011, 02:03 PM   #12
Re: Gas
More octane allows you to run more timing which generates more power. That is what is setup in a 93 octane tune.
You need to run regular in your car otherwise the only real performance gain you will get is having your wallet be a little lighter.
Old 07-18-2011, 02:23 PM   #13
Haha yeah I think I'll just stick with regular, I had a friend who had a 04 Mach 1 and he told that I would gunk up my pistons if I ran regular.
Old 07-18-2011, 02:30 PM   #14
Jamesgt08's Avatar
False
Old 07-18-2011, 10:14 PM   #15
Re: Gas
I love how some people assume 87 is "crappy gas"
Old 07-19-2011, 07:26 AM   #16
Re: Gas
anything to sell higher priced gas they will tell you
Old 07-19-2011, 09:10 AM   #17
wereKEV's Avatar
Re: Gas
So on my car with the supercharger is it safe to run regular gas or should I stick with premium?
Old 07-19-2011, 09:20 AM   #18
Jamesgt08's Avatar
Your car is probably tuned to premium.
Old 07-19-2011, 09:22 AM   #19
wereKEV's Avatar
Re: Gas
Thats what I thought I have only hade the car about 7months so I am still learning things about it.
Old 07-23-2011, 03:32 PM   #20
wmitchel51's Avatar
I fill up using premium gas. It's my understanding that you lose some hp when using regular gas. The new 5.0 adjust the timing for you depending on the gas you use.
wmitchel51 is offline   Reply With Quote
First Mustang Country705 New Member Introductions & Greetings 28 07-22-2011 06:25 PM
can't push gas pedal in more than half way help 95 gt guy 1979-1995 Mustang GT 43 07-02-2011 11:31 PM
03:34 PM
