Door Panel issue - Mustang Evolution
Old 07-26-2011, 01:48 PM   #1
fluffyGT06's Avatar
Door Panel issue
Anyone else had a problem with their "pleather" door panel falling off and what did you use to adhere it back on? I tried 3M-90 and something else. I really wish I could remember what that "something else" was but I can't. However, it didn't adhere so I added some 3M-90 and it held for the most part except for a slight air pocket. So then my driver's side started to fall. I tried just 3M-90 and it looks like it's already loosening after a few weeks. Any suggestions? I know I will have to do this again, but I do not want to keep doing it and take chances of killing the material.
fluffyGT06 is offline   Reply With Quote
Old 07-26-2011, 02:16 PM   #2
It started again?? I though you did a good job fixing it the first time.... Hmmmm
Old 07-26-2011, 02:23 PM   #3
fluffyGT06's Avatar
Re: Door Panel issue
I did too, but it seems as though it may getting loose again ... The other door is still holding up. Maybe I just have to combine the two but that process was a ^^%$%$@#%$... yeh.....
Old 07-26-2011, 06:49 PM   #4
Ninjasteffers's Avatar
I'm having the same problem!
Im taking mine back to where got them done ad getting it redone tomorrow =/ they say the 05/09 had this issues the most out of all of the yrs
Ninjasteffers is offline   Reply With Quote
Old 07-26-2011, 06:55 PM   #5
CutterWolf's Avatar
One question. When you used the 3M did you spray the door panel and the back of the pleather? And did you wait to let it dry a little first before you attached it?
CutterWolf is offline   Reply With Quote
Old 07-27-2011, 07:02 AM   #6
fluffyGT06's Avatar
I think I only sprayed the door panel, not the material. But I did let it dry a little before sticking it on. Wondering if I didn't use enough?
Old 07-27-2011, 07:07 AM   #7
I would try spraying both Danie... Maybe you needed a little more.
Old 07-27-2011, 07:10 AM   #8
fluffyGT06's Avatar
I may need to wait for one to fall off again. I would rather the moisture from the heat and humidity to make it drop than for me to pull on it and take chances of shredding the foam padding underneath. But yes, I will try that, but Im also, going to look into the Goop stuff as well.
Old 07-27-2011, 07:11 AM   #9
fluffyGT06's Avatar
Haha, damn't, getting use to this forum and I accidentally deleted the peron's quote regarding trying Goop. oops.... I a tard.
Old 07-27-2011, 07:11 AM   #10
Don't tear up fluffy now!!!
Old 07-28-2011, 12:21 AM   #11
CutterWolf's Avatar
Yep thats your problem. You need to spray both then let them tack up a bit and then attach it.
Old 07-28-2011, 01:36 PM   #12
fluffyGT06's Avatar
Maybe I will try that first before I go out and buy anything else. Thank you! I will let all know how it turns out.
Another Issue (overheating) bradh2414 Pre-2005 V6 Mustang 18 07-27-2011 04:19 PM
Transmission issue goherd 2005-2010 V6 Mustang 2 07-22-2011 07:18 PM
#8 piston issue????? wnt2gofst 2011-2014 Mustang GT 2 07-21-2011 05:25 PM
Overheating issue Edge4 1979-1995 Mustang GT 11 07-19-2011 10:06 PM
Fuel gauge issue macmarine39 1979-1995 Mustang GT 7 07-16-2011 06:19 PM
05:50 PM
