Throttle Body Whistles - Mustang Evolution
Old 08-10-2011, 09:15 PM   #1
GTtopgear's Avatar
I upgraded the throttle body about 2 months ago and it whistles alot louder then it did befor. Is that normal or is something loose?
Attachment 30131
02 GT : LT headers, H pipe, Cat back, 80mm TB, Intake, Strut tower bar, lightweight pullies All BBK, drilled and slotted rotors, Clear headlights, Eibach Pro Kit, Hid kit for both head and fog, chin spoiler,18' chrome 2010 GT wheels with nitto tires
GTtopgear is offline   Reply With Quote
Old 08-10-2011, 10:40 PM   #2
There might be a leak
16218 is offline   Reply With Quote
Old 08-10-2011, 10:45 PM   #3
Jamesgt08's Avatar
Check for vacuum leaks.
Jamesgt08 is offline   Reply With Quote
Old 08-11-2011, 09:20 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Throttle Body Whistles
have you done any other mods since u installed the t.b.? i.e. cold air tube, air filter or changed the tune? changes in air/fuel ratio can cause the t.b. to whistle louder or be more quite. even changing the intake itself can cause the t.b. make more or less noise if it's aftermarket
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 08-11-2011, 09:31 AM   #5
GTtopgear's Avatar
I did change the intake manifold
Old 08-11-2011, 10:33 AM   #6
Titus Wadicus
svtlx's Avatar
well thats most likely your cause for the increased noise...
Old 08-11-2011, 02:12 PM   #7
GTtopgear's Avatar
Any way to fix it or is it just the way it's going to be
Old 08-11-2011, 02:58 PM   #8
Find exactly where its coming from with a mechanic stethoscope
Old 08-13-2011, 10:24 AM   #9
Titus Wadicus
svtlx's Avatar
itsa trade off with aftermarket stuff. sum ppl have drilled holes in the throttle blade, but i definatley dont recommend it. u could try a different brand of t.b. but it's not a gaurentee.
mine whisteld with two different intakes... the third intake im using now only does it at idle at certian temps
Throttle body help. austinray4142 Pre-2005 V6 Mustang 4 07-26-2011 04:29 PM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 09:43 PM
Any 2011 AT owners out there -- weird throttle response? illestdomer2005 2011-2014 V6 Mustang 5 07-09-2011 01:36 PM
Throttle body cleaning Mustanglife Pre-2005 V6 Mustang 10 07-04-2011 02:32 PM
04:04 PM
