parts - Mustang Evolution
Old 08-28-2011, 12:00 PM   #1
parts
Need help with the name of the part that the headlights mount in all fiberglass 99 mustang
sandy farr is offline   Reply With Quote
Old 08-28-2011, 12:28 PM   #2
Titus Wadicus
svtlx's Avatar
Re: parts
i believe its called a "header panel"...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 08-28-2011, 01:46 PM   #3
Thanks I need to order one ill try it
Old 08-28-2011, 05:28 PM   #4
Re: parts
headlight alignment panel its long and goes all the way across the front, rather easy to replace. Its generally painted as well to match the car.
Shelby bumpers mustangchassy Mustang Paint, Appearance & Detailing 9 08-24-2011 08:51 PM
Looking for places to buy parts for an 86 Otlaw80 1979-1995 Mustang GT 12 08-18-2011 03:47 PM
Parts for sale: make offers greenpony02 Mustang Parts for Sale and Wanted 5 08-16-2011 05:22 PM
08:40 AM
