Any have 4.56's - Mustang Evolution
Old 09-01-2011, 12:56 PM   #1
Any have 4.56's
Does anyone have 4.56's installed in an 03 straight axle.?.? No one has an answer as to why my diff cover doesnt clear the ring gear.?.? Richmond says the the stock cover should work just fine but it doesn't! The ford racing one I bought also doesn't clear. Any help would be nice!
Mach is offline   Reply With Quote
Old 09-03-2011, 02:04 AM   #2
dimo's Avatar
Region: South Dakota
Wow, those are tall gears. Here's what I found online:
"If you are using 4.56 gears or lower (numerically higher), you will need to notch the cross pin to clear the outer tip of the teeth on the ring gear." That's for if you're using the stock carrier, and FRPP's might not be big enough either
Grabber orange is NOT yellow!!!
dimo is offline   Reply With Quote
10:29 AM
