clutch noise - Mustang Evolution
Old 09-12-2011, 06:48 AM   #1
clutch noise
I'm sure this has been addressed, but in my 04 Mach 1 I have a chirping sound when my foot is off the clutch. The moment I push the clutch in it stops. Car has a firewall cable adjuster and I believe a centerforce clutch
Thanks guys
rix71gt is offline   Reply With Quote
Old 09-12-2011, 07:22 AM   #2
Re: clutch noise
throwout bearing, try taking up more slack in the cable so that you have only 1/2 inch of pushing in the clutch petal from the top before the rpms climb (holding gas constant while driving at like 50mph)
The clutch petal should be firm at the top (no flop)... just be sure to leave enough so you are not engaging the clutch all the time
Old 09-12-2011, 11:29 AM   #3
I appreciate the input. Ill make adjustments until it clears up.
Thanks
Old 09-12-2011, 12:23 PM   #4
Re: clutch noise
You probably have a throwout bearing going bad.
Squeaks when it is unloaded, but when pressure is applied it quits.
My daughter has an 04 Mach I and it had the same issue. Replacing the throwout bearing cured the problem squeak.
P.S. Spector, JFYI flowers have petals, cars have pedals.
Old 09-12-2011, 07:54 PM   #5
Did a test tonight omw home. There's a good inch and a half of pedal travel before the clutch begins to disengage. Gonna adjust it in the am
Clutch eouellette18 2005-2010 Mustang GT 9 09-08-2011 03:51 PM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
Spec or ram clutch 04machazblue 1996-2004 Mustang GT 3 08-23-2011 04:36 PM
Need advise on a new clutch j4gwig General Mustang Discussion 1 08-01-2011 07:51 PM
09:30 AM
