04 cobra shifting problems - Mustang Evolution
Old 09-14-2011, 07:42 PM   #1
NickGeezy's Avatar
My 04 cobra is hard to shift at high rpms when going fast it's hard to get from 1st to 2nd and 3rd idk if I need to adjust my clutch or maybe firewall cable adjuster or quadrant..
NickGeezy is offline   Reply With Quote
Old 09-14-2011, 07:50 PM   #2
Filibuster
Could also be the syncros getting worn...
XXSTEVEO66 is offline   Reply With Quote
Old 09-14-2011, 08:08 PM   #3
Re: 04 cobra shifting problems
What is your clutch setup? Also do you have a firewall adjuster and aftermarket quadrant? And, what cable are you running?
Old 09-15-2011, 07:18 AM   #4
when I purchased my 03 cobra I had the same issues... turned out the clutch was just unadjusted (clutch quadrant/cable were OEM). If your clutch petal is really low and when you shift you have to push it all the way to the floor you probably have the same issue.
If its the OEM clutch to manually adjust it you need to slide the seat back, raise the steering wheel and then reach in and put your left hand on the clutch, push it in. Notice on the right above the gas petal you will see the white plastic half moon looking thing wit h the clutch cable on it. Hold the quadrant with your right hand.
Slowly ease out the clutch, the quadrant WILL move (rotate what ever) back and you just hold tension on it. This will cause the quadrant to make a noticeable "click" sound. Do this a couple times and test the clutch and continue until happy.
You want about a half inch (at least NO less) of pushing in the clutch from the top before the clutch starts to slip. To test for slip drive the car at 40-50mph etc hold the gas steady and ease in the clutch, when the rpms start to jump the clutch is slipping.
This WILL raise the clutch up and make it high... its just part of it. If you shift REALLY hard (push in the clutch petal hard) it may nonadjustable itself... mine does now and again.
If you ever put your foot under the clutch petal and raise up it will unadjust itself.
Old 09-15-2011, 08:40 PM   #5
NickGeezy's Avatar
Alright yeah it's oem I'll try it out and see what happens thanks for the heads up. If not that I'll take it I'n the shop!
Old 09-15-2011, 09:36 PM   #6
Probably one of the best mods for these cars is a firewall adjuster and quadrant. Makes worlds of difference in clutch feel and you can move the clutch level higher or lower depending on your driving style. I like mine right up top and was able to adjust exactly for that for powershifting.
Old 09-21-2011, 09:11 AM   #7
drusmith's Avatar
Send a message via Yahoo to drusmith
I have it and love it! Mine is set up top as well.
Hey NickGeezy,
Lowfyn and SpectorV have been very helpful to me in the last year after I bought my 03 Cobra. Good guys and lot of good info! Let us know your outcome as well!
drusmith is offline   Reply With Quote
Old 09-21-2011, 10:41 AM   #8
I would have went with an aftermarket adjuster but... I hate petal flop and the correct adjustment requires the petal to be HIGH due to the slack you have to take out of it... MaximumMotorsports makes a petal height adjustment thing but not sure how well it works.
Need help 03 cobra Jamesgt08 1996-2004 Mustang GT 27 09-16-2011 06:39 PM
Cobra Pricing Opinions... 2008Shelby SVT Mustang 25 09-04-2011 03:49 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
07:45 AM
