Nasty window sound - Mustang Evolution
Old 09-17-2011, 05:10 PM   #1
austinknoll's Avatar
Nasty window sound
I'm having this nasty sound when my window is rolled up and I roll it down. It all started when they tinted it. I took off my door panel and saw metal shavings on the bottom. It only happens sometimes but it is often
Please help
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 09-18-2011, 12:15 AM   #2
Thanks
65 Mustang coupe
Old 09-18-2011, 04:39 AM   #3
fordfan100's Avatar
You can try and lubricate the track there should be some special lubricant you can get from an auto store
fordfan100 is offline   Reply With Quote
Old 09-18-2011, 10:30 PM   #4
But it's like a really bad nasty sound. And metal shavings in the door
65 Mustang coupe
Old 09-19-2011, 05:22 AM   #5
Re: Nasty window sound
Sounds like they may have knocked the window off the guides or track.
Remove your door panel and take a close look at it while moving the window up and down.
Old 09-19-2011, 09:06 PM   #6
I moved these little things at the top and haven't heard it so far hopefully it works
65 Mustang coupe
Old 09-25-2011, 10:35 PM   #7
It didn't work. It still makes this nasty cracking sound. It's usually get slower when my window gets close to the top. Then when I roll t down, it makes this ugly sound. Any help?
65 Mustang coupe
Old 09-25-2011, 10:50 PM   #8
Did you pull of the panel and watch and listen to it as you rolled it up and down? Your problem is in there, so you will have to keep looking and listening until you find it.
You may be losing the gearbox in the window motor.
Old 09-25-2011, 11:38 PM   #9
I pulled off the door panel and found metal shavings in the middle I can't find what is hitting
65 Mustang coupe
Old 09-25-2011, 11:46 PM   #10
You will have to keep looking using mirrors or whatever it takes to find the problem.
No one will be able to help you any further without being able to physically look at your car.
Old 09-26-2011, 09:11 AM   #11
96civic87's Avatar
Make sure the screws r tight and everythung is secure not loose while operating
96civic87 is offline   Reply With Quote
Deep Sound 559Danny 1996-2004 Mustang GT 10 09-29-2011 06:09 PM
Window Tinting crkmonzo 1979-1995 Mustang GT 8 09-11-2011 03:34 PM
Window tint MVP u eNVy ME Mustang Paint, Appearance & Detailing 19 09-11-2011 09:11 AM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
05:55 PM
