3.8 v6 strocker kit - Mustang Evolution
Old 09-29-2011, 10:19 PM   #1
3.8 v6 strocker kit
I want to stroke my 3.8 v6 to 4.2 or 4.4
If I stroke it how much HP will I get also going to put new camshaft
Ported cylinder heads, longer push rods,ported upper intake and lower intake .... what cylinder head is better twin port or single port with 3 valvles
My stock 3.8 v6 only pushes 140 or 145 hp I want to at least get in the range of 200 -300 HP
I found all this in Tom morana website
sergio159 is offline   Reply With Quote
Old 10-05-2011, 08:13 AM   #2
kickerofdoom's Avatar
What year mustang and 4.2 will add 20 hp
Old 10-05-2011, 08:15 AM   #3
94 mustang 3.8 v6
Old 10-05-2011, 08:18 AM   #4
Yeah they were slow and your HP is around 140. I would say get a second engine a 99+ and build it. Add a Windstar intake,4.2 stroker kit,cams,port and polish.220-230 HP I would guess then
Old 10-05-2011, 08:30 AM   #5
Do you know what cylinder heads are better twin port or single port
Old 10-05-2011, 09:17 AM   #6
Re: 3.8 v6 strocker kit
if you build a 4.2L single port, if its built good with normal or high compression you should see 250-280rwhp maybe more but around that. It all depends on the specs and how the motor is built etc~ it can vary greatly.
Old 10-05-2011, 09:38 AM   #7
Is a 5v better than a 3v
Are you a v6. spector v
Old 10-05-2011, 10:21 AM   #8
what do you mean by 5v or 3v?
I currently dont own a V6 but I have previously owned two. Your stock pre 99 V6 is around 150hp/220tq~ and MUCH less than that at the rear wheels (17% for manual 22% for auto is what you will lose from engine to rear wheels)
The numbers I quoted are rear wheel hp. You can give some guys a call that deal with this like supersixmotorsports and see what they say.
Old 10-05-2011, 10:26 AM   #9
Cylinder valves on Tom Moran's website he has 3 valves and 5 valves
Old 10-05-2011, 11:37 AM   #10
If istroke 2004 3.8 v6 would I be reaching 200-230 HP
Old 10-05-2011, 11:41 AM   #11
there cant be 5 valve heads for the 3.8l mustang motor? or even 3, maybe you mean valve job (3 or 5 angle)
Old 10-05-2011, 11:45 AM   #12
Yeah so if it has a 5 valve job is it better than 3valve job
Old 10-05-2011, 01:58 PM   #13
All I know is that supersport more expensive I know another website and people who are cheaper
Old 10-05-2011, 02:22 PM   #14
well 5v is better I am sure, but how much? for a street car probably not a huge deal~
Old 10-05-2011, 02:33 PM   #15
What website you guys recommend that cheaper
Old 10-05-2011, 03:06 PM   #16
Las0mbra's Avatar
Supersixmotrsports.com is pretty good too
Old 10-05-2011, 09:01 PM   #17
http://www.gssmotorsports.com/Project_Frostbite.html check this website
How to: 4.2L V6 Mustang Engine Swap Danger Dude Pre-2005 V6 Mustang 85 11-14-2015 07:51 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
302 5.0 v8 from a 95 f150 into a 95 mustang 3.8 v6 Pascullon Pre-2005 V6 Mustang 12 07-28-2011 11:06 PM
My 1999 3.8 v6 cakedout Pre-2005 V6 Mustang 108 07-11-2011 06:46 PM
» Members Mustangs
none
okfoz
Kona
WhoDat
Add your Mustang
06:19 AM
