Speed demon? - Mustang Evolution
Old 10-08-2011, 01:54 AM   #1
Evolution's Avatar
Speed demon?
I know there is lot of you out there with a need for speed. I was hoping some of you may be able to help me with horsepower improvements. I have a 96 v6, with k & n filter that's it. I know someone that has a supercharger I could buy for $500, it's a eaton m90. Is it worth it? Im looking for more torque, more speed of the line. I'd there any reasonably priced things I can do to increase horsepower and torque?
Thanks!
Evolution is offline   Reply With Quote
Old 10-08-2011, 02:49 AM   #2
Personally id stay away from the secound hand stuff as much as possible (obviouslly u got to do what u have to) but if its in good shape it may be worth checking out
Hawk is offline   Reply With Quote
Old 10-08-2011, 07:00 AM   #3
onesickstang01's Avatar
The supercoupe swap brings a good bit of power. You want to do the heads along withthe supercharger though. Theres lways nitrous but you want a good kit with allthe safety switches. And if you dont want to go all out with big swaps then you can do the windstar intake swap
onesickstang01 is offline   Reply With Quote
Old 10-08-2011, 09:59 PM   #4
Evolution's Avatar
I heard the supercharger only really works at higher speeds and if you push the pedal right to the ground. True?
Old 10-08-2011, 10:11 PM   #5
No its a roots style so will come on early and depends which pulley you run how much power it will make. You can easily make it run down a lightly modded 99+ gt
Old 10-08-2011, 10:49 PM   #6
Evolution's Avatar
Oh, so is it worth the buy? I'm thinking of getting that or the new iPhone 4s. Lol
---------- Post added at 08:32 PM ---------- Previous post was at 08:23 PM ----------
And what pulley should I run it off to get maximum power?
---------- Post added at 08:49 PM ---------- Previous post was at 08:32 PM ----------
The supercharger had never been used, he never got the time to instal it.
Old 10-09-2011, 08:33 PM   #7
Then its only a good deal if its worth it to you.
Old 10-09-2011, 09:30 PM   #8
Re: Speed demon?
There's alot more to adding a supercharger than just bolting it on.
At a minimum you will need new intake tubing, fuel injectors, belt/pulley setup, appropriate gaskets, and a good tune.
A better mod, in my opinion, would be doing a split port swap on your engine.
It entails heads, lower intake, upper intake from a 99-04 car. Would be an excellent time for a good cam swap as well.
Old 10-09-2011, 10:36 PM   #9
Evolution's Avatar
Is it better to do than a supercharger? Is it easier? Adds more hp/torque? Cheaper?
Old 10-10-2011, 08:38 AM   #10
You would be best of swapping a complete supercoupe motor into it that way you have the same motor with better heads and the supercharger but complete with all accessories, injectors, intake, everything. Its a simple swap and drops right in but you just need to extend a few wires
Old 10-10-2011, 08:45 AM   #11
Re: Speed demon?
Coyote swap....FTW..
Old 10-10-2011, 11:04 AM   #12
Eturner's Avatar
That's what I want to do!!!... Hahahahaha
Old 10-10-2011, 11:43 AM   #13
Re: Speed demon?
you cant just put the M90 supercharger onto your car, it takes MUCH more work to do it and the end result is not that great.
Old 10-11-2011, 12:11 AM   #14
Evolution's Avatar
Okay, eaton m90 supercharger( not worried about the extra parts just on how good it is) or a new exhaust system( like magnaflow or flowmasters) i only have a v6 but the stock exhaust isn't anything special.
Thanks.
Old 10-11-2011, 08:30 AM   #15
Re: Speed demon?
exhaust (catback) will add about 5rwhp, the M90 is a crappy blower compared to a whipple or kb etc but it can get the job done if ported etc but you wont be able to mount it to your engine with out an adaptor kit or the full supercoupe motor for the most part.
Old 10-11-2011, 08:37 AM   #16
Evolution's Avatar
So to get the job done with a supercharger im looking at over $1,500? I think I might put an exhaust for the nice sound, get a supercharger for my next car.
Old 10-11-2011, 10:23 PM   #17
With the v6 i prolly would go turbo over sc myself if i could choose one or the other.ull find the gains in the higher rpms nicer with little to no parsitic loss of any kind so for me if i would build that motor i would start in head work (new.... Probably. better springs port &polish so on and so forth.) . After i had some fun with that, then a nice cam and tune.burn out city. And when adding the turbo would come up for its addition to the games. i would beef up the bottom end a little. maybe a forged crank. start with lower boost and work up. Start adding forged parts as u increse boost levels and allways retune as u increse boost and add new parts. But never forget to have some fun between steps.
Factory speed control or dealer speed control (cruise control) Otlaw80 1979-1995 Mustang GT 6 08-18-2011 07:42 PM
5 speed shifter for 79 FoxyIndy79 1979-1995 Mustang GT 2 08-13-2011 03:27 PM
Speed tech jsearcy 2011-2014 Mustang GT 9 08-01-2011 08:30 AM
11:47 AM
