What is easier? - Mustang Evolution
Old 10-17-2011, 08:31 AM   #1
Brandanxstang21's Avatar
What is easier?
I am putting new valve springs, cams, cam gears, and long tube headers on my 99 gt. Will it be easier to pull the motor or try to do it while it's still in the car?
Brandanxstang21 is offline   Reply With Quote
Old 10-17-2011, 08:33 AM   #2
bobsurvives's Avatar
If you can pull the motor that would be the easiest way to in stall those internals. I'm not sure about the headers, I just know that they'll be a pain in the butt... But you'll get them in there.
bobsurvives is offline   Reply With Quote
Old 10-17-2011, 09:05 AM   #3
That's what I was thinking, but would I put the headers on before I put it back in or after?
Old 10-17-2011, 09:36 AM   #4
onesickstang01's Avatar
Drop k member with entire motor. Easiest way
onesickstang01 is offline   Reply With Quote
Old 10-23-2011, 01:45 AM   #5
t0t4lbl4ck0ut's Avatar
I just changed my valves springs and cammed my car and I'll tell you this right now. BUY NEW LIFTERS. My motor now sounds like a diesel cause the increased valvetrain noise. My car already had long tubes so I'm not sure about the difficulty of that but it's pretty easy to do the rest in the car. Just use a compressor to keep the valves from dropping in and it's simple. Well I shouldn't say simple just not hard just tedious with the valve locks. If you don't remove the heads PLUG YOUR OIL RETURNS. I dropped 2 locks down them somehow and had to fish them out with a magnet.
t0t4lbl4ck0ut is offline   Reply With Quote
Good to be Back in a Stang !!!! Kystang615 2011-2014 Mustang GT 35 09-24-2011 06:30 AM
08:49 PM
