Break line leaking - Mustang Evolution
Old 10-24-2011, 11:14 PM   #1
Siendly22's Avatar
Break line leaking
Folks need some help my break line is leaking on the right front wheel. It just sudden. Any suggestion?
Siendly22 is offline   Reply With Quote
Old 10-25-2011, 05:45 AM   #2
Brad.krieg's Avatar
Send a message via Yahoo to Brad.krieg Send a message via Skype™ to Brad.krieg
R & R, it's the only thing you can do.. If it's getting on the rotor and pad it could cause a malfunction. Not to mention if you loose enough fluid you'll have no brakes. Take it to a shop and get it fixed with a warranty. Shouldn't be that bad of a job. I'd say a couple hundred : line, new fluid, possible rotor/ pad replacement + labor. It can add up quick. But peace of mind is priceless
Brad.krieg is offline   Reply With Quote
Old 10-25-2011, 07:46 AM   #3
Re: Break line leaking
could just be the brake line from the caliper to the hard line, check the connections (will need a brake line wrench not a standard size I dont believe)
Old 10-25-2011, 11:35 AM   #4
Siendly22's Avatar
Thanks , I will bring my car to a shop get it fix today. And have peace of mind )
Old 10-25-2011, 11:55 AM   #5
Brad.krieg's Avatar
Good man, best to let a professional work on something Like that if your not familiar with how a brake system works. It sounds like its leaking a pretty good amount of fluid to be noticed like that. Hopefully its something small like our friend above me mentioned here^. Best of luck man, stay safe.
Old 10-25-2011, 01:27 PM   #6
Siendly22's Avatar
Thanks man
Tips on painting break calipers? Stangteen Mustang Wheels & Tires 45 10-09-2011 01:50 PM
ebay headlamps leaking - common issue? solution? paradigm 1996-2004 Mustang GT 3 10-09-2011 11:07 AM
Vaccuum Line Question crkmonzo 1979-1995 Mustang GT 4 09-09-2011 11:01 AM
What oil should be used on my cam break in? wc3john 1979-1995 Mustang GT 6 08-14-2011 11:43 PM
Vac line location zrider07 1996-2004 Mustang GT 3 08-01-2011 10:39 PM
02:06 AM
