Blower/supercharger - Mustang Evolution
Old 10-25-2011, 01:06 PM   #1
shsfresh87's Avatar
Region: West Virgina
Blower/supercharger
I want a 3 barrel blower for my 01 GT, but I'm having trouble finding an actual brand name, all I can find are under the hood superchargers, can anyone help? Thanks
shsfresh87 is offline   Reply With Quote
Old 10-25-2011, 02:00 PM   #2
Can a super charger mess up Ur engine on the long run?. Cuz I'm thinking bout installing one 2 I got a mustang Gt 02.
diego4.6gt is offline   Reply With Quote
Old 10-25-2011, 02:05 PM   #3
Titus Wadicus
svtlx's Avatar
Re: Blower/supercharger
a boosted motor will live as long as a n/a motor if properly installed and tuned.
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-25-2011, 02:45 PM   #4
What do you mean?3 barrel?are u talking about a scoop?like this http://images.google.com/imgres?q=bl...iw=360&bih=555
Old 10-25-2011, 03:26 PM   #5
shsfresh87's Avatar
Yea
---------- Post added at 04:26 PM ---------- Previous post was at 04:25 PM ----------
Yea like that
Old 10-25-2011, 03:30 PM   #6
Yea
Yea like that
That is just a scoop.pretty much used for carbed setups.it attaches to a carberator.
Old 10-25-2011, 03:32 PM   #7
shsfresh87's Avatar
What is it called though? Can you give me a brand name?
Old 10-25-2011, 03:35 PM   #8
You are fuel injected.I don't think you'll find a scoop like this for you car unless you have a carb conversion.but just google blower scoop.
Old 10-25-2011, 03:38 PM   #9
shsfresh87's Avatar
K, thanks
Old 10-25-2011, 03:47 PM   #10
When you use a roots type blower where a carb sit on top sometimes especially with bigger size blowers the best place to get air is gonna be outside the hood.because most of the time a blower and carb setup dont fit under a normal hood.also a big blower is gonna need more air.that's where this type of scoop comes into play.
---------- Post added at 04:47 PM ---------- Previous post was at 04:42 PM ----------
Np.glad I could help
Old 10-25-2011, 03:48 PM   #11
shsfresh87's Avatar
O, ok, I was getting confused bc I thought the scoop was a form of supercharger
Old 10-25-2011, 03:51 PM   #12
They are always used with SC so I can see how you could get confused.
---------- Post added at 04:51 PM ---------- Previous post was at 04:50 PM ----------
They do look bad a** though
Old 10-25-2011, 04:00 PM   #13
shsfresh87's Avatar
I love the look, and on an 01 GT it would look bad @as bc the body style is very muscle looking, n my opinion it's the best modern mustang body style compared to the newer 1s
---------- Post added at 05:00 PM ---------- Previous post was at 04:55 PM ----------
Wow it corrected ***
---------- Post added at 05:00 PM ---------- Previous post was at 05:00 PM ----------
I mean a**
09:35 AM
