High speed vibration - Mustang Evolution
Old 11-04-2011, 01:57 PM   #1
Weeg15's Avatar
I have a high vibe coming from the back of the car at around 70+ just wondering on where to start looking to pin point this problem
Weeg15 is offline   Reply With Quote
Old 11-04-2011, 02:58 PM   #2
I heard on other threads of people having trouble with there drive shaft bolts loosening.but I always start with tires when it comes to vibration.check for balance and busted belts.
Old 11-04-2011, 04:22 PM   #3
Weeg15's Avatar
Yeah that was my thought too I just had the driveshaft off to do my rear and the car is in need of new sneakers so I'll try that if not maybe a new driveshaft
Old 11-04-2011, 04:23 PM   #4
MC770's Avatar
Re: High speed vibration
Yes, definitely check your rear u-joints bolts mine was vibrating from 40 and up and got worse the faster you went. We checked the bolts and they were only in there hand tight
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 11-04-2011, 04:26 PM   #5
it is a good idea to use loctite on the driveshaft bolts.just double check that they didnt back out.you probably dont need a whole new driveshaft just u joints if they are worn.
Old 11-04-2011, 04:59 PM   #6
Weeg15's Avatar
Yeah I'm def gunna get on it this weekend
Old 11-04-2011, 05:03 PM   #7
deadsp0t's Avatar
Yes, if you have had them out recently it is likely the case. I'd check them ASAP! Use brake cleaner to clean the bolts and holes and blue loc tite. Any trash will negate the loc tite.
That's unimpressive
Old 11-04-2011, 05:12 PM   #8
Weeg15's Avatar
That's the thing though it vibrated real ba like that ever since I bought the car so I'm open to anything cause I don't wanna vibrate my new rear(Richmond 3.73) apart and be out the money
Old 11-04-2011, 05:17 PM   #9
deadsp0t's Avatar
Could be as simple as the balance or wear on the tires. You say you need tires? Even if you don't consider balancing them. Also the driveshaft could be out of balance. Also if the tranny has been swapped the driveshaft could be to short(spacers are available) if this is the case you'll be able to see marks on the front yoke where it was further inside the tranny at one time. I had this issue when I swapped trannys.
That's unimpressive
Old 11-05-2011, 08:06 PM   #10
Weeg15's Avatar
Ok thanks ima start with the tires and go from there
Old 11-06-2011, 04:19 AM   #11
deadsp0t's Avatar
Np! Hope you find it!
That's unimpressive
Old 11-06-2011, 07:50 AM   #12
Yes vibration it can be a mounting and valance, but check the u joint, those cause a lot of vibration 2
2003CobraSvt is offline   Reply With Quote
« atomic efi | Rotors »
Speed demon? Evolution General Mustang Discussion 16 10-11-2011 10:23 PM
Heavy vibration in rear end Blackedout Pre-2005 V6 Mustang 23 09-15-2011 02:35 PM
Factory speed control or dealer speed control (cruise control) Otlaw80 1979-1995 Mustang GT 6 08-18-2011 07:42 PM
5 speed shifter for 79 FoxyIndy79 1979-1995 Mustang GT 2 08-13-2011 03:27 PM
08:46 PM
