Idle issues HELP - Mustang Evolution
Old 11-18-2011, 04:41 PM   #1
Idle issues HELP
I have a 95 3.8 . When I start it it revs up to. 3000 rpm . I put it in gear it drops to 1500 and stays there. I've checked for vacuum leaks,changed the throttle positioning sensor,changed mass airflow, o2 sensors , even a new ecu. I'm lost can anyone help?
DHall31 is offline   Reply With Quote
Old 11-18-2011, 04:54 PM   #2
Mustang Convert's Avatar
Clean or replace you iacv.
Toys: 83 GT 5.0
-------98 V6 3.8
Daily: 06 RSX Type S 2.0
Roadtrips: 05 Odyssey EX 3.5
Mustang Convert is offline   Reply With Quote
Old 11-18-2011, 05:39 PM   #3
Re: Idle issues HELP
I Tried that also it still is revving think resetting the ecu would work?
Old 11-18-2011, 05:59 PM   #4
Have you checked the dpfe. If you have a haynes manual, it will tell you the voltage specs. Get the autozone one if you do need one. I found out, after spending $100 for a "genuine" motorcraft dpfe, that they get that same piece, scrape off the logo, and sell it for a third of the price!
Toys: 83 GT 5.0
-------98 V6 3.8
Old 11-18-2011, 06:03 PM   #5
Dpfe?
Old 11-18-2011, 06:11 PM   #6
(edited above some)
Diffetential pressure.... Lol. I forget the exact name, but it's vacuum lined in with the egr. It makes sure the egr is functioning properly.
You'd need a multi-meter to check it.
---------- Post added at 07:11 PM ---------- Previous post was at 07:09 PM ----------
Any time you disconnect the battery for a few min, hours, days.... It should reset the ecu. Couldn't hurt. Just make sure you have your radio code.
Toys: 83 GT 5.0
-------98 V6 3.8
Old 11-18-2011, 06:14 PM   #7
(edited above some)
Thank I'll give it a try tomorrow
Old 11-19-2011, 08:32 PM   #8
Well that didn't work I'm all out of ideas
Old 11-19-2011, 09:21 PM   #9
Eturner's Avatar
You said you got a new ecu!.. Is it possible that the program in it is wrong??.... ie. idle is set real high for some reason?!?.... Don't know just trying to brainstorm a little for ya!!.....
Old 11-23-2011, 05:33 PM   #10
I've tried everything everyone has told me to no avail this car is really ticking me off lol I can't figure this thing out . I'm not a mechanic and mechanics are scratching their heads on this one. Any more advise will be greatly appreciated.
idle problems brian94gt 1979-1995 Mustang GT 22 11-21-2011 08:44 PM
humming noise during idle robertoortiz85 1996-2004 Mustang GT 6 10-23-2011 02:12 AM
Stupid idle NateNasty 1979-1995 Mustang GT 23 10-17-2011 07:12 AM
Misfire issues Ghostedmind Pre-2005 V6 Mustang 1 10-02-2011 12:52 AM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
07:38 PM
