91 gt diferential posi - Mustang Evolution
Old 11-26-2011, 04:56 AM   #1
Punks86coupe's Avatar
Does anyone kno the stock diferential gear size on the this particular diferential. I'm getting the complete rear end off this guy on craigslist. Was wondering if anyone knew? Will be putting it on my 86 coupe
As of what he told me nothing has been touched "geared" it's all stock 4 lug and his car was a 5.0 manual trans. Posi
---------- Post added at 04:56 AM ---------- Previous post was at 04:54 AM ----------
I'm assuming it's a 8.8
Punks86coupe is offline   Reply With Quote
Old 11-26-2011, 07:02 AM   #2
deadsp0t's Avatar
2.73 or 3.08.. Likely 2.73.. If its never been opened there should be a metal tag with a bunch of numbers, and you should be able to see a gear size among them.
That's unimpressive
Old 11-26-2011, 09:38 PM   #3
aegischief's Avatar
First, it is a 2.73 gear ratio. Second, it's not a posi but rather a limited slip. This differential uses clutches to apply power to both wheels while still allowing a little bit of slip for safe normal driving. Unless it has a ton if miles on it, should be fine.
aegischief is offline   Reply With Quote
Old 11-27-2011, 08:00 AM   #4
deadsp0t's Avatar
They are NOT all 2.73..
That's unimpressive
Old 11-27-2011, 09:34 AM   #5
aegischief's Avatar
There are some 3.08s out there but a overwhelming majority of the gearsets are 2.73.
Old 11-27-2011, 10:26 AM   #6
Thank you guys I bought the diferential and according to the tag it's a 8.8 and it's says 2.73
Right now I have a 7.5 will it be a clean swap? Or will I need other parts to complete the installation? The diferential is complete from drum to drum with e brakes.
Going into my 86 coupe
The guy gave me the 91 v8 gt front spindles, calipers and diferential for 65$
Since he went with a 96 set up or 95
Old 11-27-2011, 12:43 PM   #7
aegischief's Avatar
Yep. Will go right in. I recommend that you put on some aftermarket control arms and replace the upper bushings before you install. Will save you a ton of time and headache later.
97 Mustang GT Build Brainstorming TheJigShow 1996-2004 Mustang GT 19 11-15-2011 03:34 PM
Will Stock 1998 GT H-Pipe Fit My 2003 GT? Brent 1996-2004 Mustang GT 5 10-12-2011 08:44 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
01:33 AM
