Automatic Launching on races - Mustang Evolution
Old 12-12-2011, 10:35 PM   #1
phobik's Avatar
I own a 2010 Mustang GT AUTO with JLT CAI/Tune & a roush catback exhaust. I just wanted to know some tips on how to launch off the line with an Automatic. I've always wanted to know just for future reference.
phobik is offline   Reply With Quote
Old 12-12-2011, 10:43 PM   #2
DaBluedude's Avatar
Left foot on brake, right foot on gas. Build revs, let go of brake. You could look at a line lock kit and installing a stall converter for better acceleration.
2003 Mach 1
Old 12-12-2011, 10:49 PM   #3
phobik's Avatar
What's the best rpm to launch from?
Old 12-13-2011, 02:10 AM   #4
DaBluedude's Avatar
... on stock rubber no more than 3500rpm... but it depends on lots of stuff.
2003 Mach 1
Old 12-13-2011, 02:16 AM   #5
phobik's Avatar
What stuff? Wud it be smart to leave traction control on or off?
Old 12-13-2011, 08:41 AM   #6
DaBluedude's Avatar
Generally off. Make sure you practice in a controlled setting. Get comfortable with it first...
2003 Mach 1
Old 12-13-2011, 09:08 AM   #7
phobik's Avatar
I thought that wud always be a good launching tip but I never did it because I thought I wud burn wheel off the start & it wud delay me in some way Lol
Old 12-13-2011, 09:28 AM   #8
JimC's Avatar
Re: Automatic Launching on races
The basic technique is as said. Left foot on brake, bring the RPM's up, give it gas and release the brakes.
On the stock stall convertor you won't be able to get up to 3,500 rpm. Stock is only about 2,000 maximum. If you try to stall it up to 3,500 on the automatic it will just push through the lights, or stall out the engine.
The line lock is really for burnouts, not for the launch. It locks your front brakes but releases the pressure on the rear brake so that you can spin the tires without burning up the brakes and heating the rotors up.
It will really take some time at the tree to determine what is best for your car, as well as what is best for that day and track prep. Lots of things affect the launch - a cold day and cold track will make it tough to hook up for example and will require more burnout to get the tires heated up enough. Then to avoid spinning you might have to ease into it more on that day.
I found that generally my car likes about 1700 and punch it to flash the convertor then release the brakes. It is a matter of timing on flooring it and lifting off the brake pedal to let the car roll out.
My drag radials seem to work best with 20 lbs, any lower and the car bogs and any higher and they spin. If I try to run on my street tires I have to roll into the throttle at launch or the rear tires just spin for 60' - so on street tires it is a quick spin to clean them off, then launch basically from idle with easing into the throttle the first 60'.
It takes practice to determine what is best for you and your car. Tire pressure, type of tire, how many cars have gone down the track before you, your rear control arms, and the angle of the rear control arms all affect the launch. This season I made some suspension changes early and my 60' times and ET were suffering (but the MPH was up). I kept trying different things but times still weren't where they should be. Finally at the end of the season I decided to adjust the angle on the lower control arms because I had set them to the lowest point on the relocation brackets - and that was the change I needed to get the weight transfer; the severe angle was lifting the entire car rather than shifting the weight to the back.
JimC is offline   Reply With Quote
Old 12-13-2011, 09:41 AM   #9
phobik's Avatar
I would basically be launching off stock wheels Lol
Old 12-13-2011, 10:36 AM   #10
JimC's Avatar
On stock tires and wheels then, along with stock suspension, you will likely want to ease into the throttle more then.
Otherwise you will end up on the stock wheels as you blow the tires off!
Old 12-13-2011, 11:16 AM   #11
DaBluedude's Avatar
+1
If you want to get into drag racing its worth it to invest in some performance rubber.
2003 Mach 1
looking for turbo for 2001 v6 mustang automatic shaloubin Pre-2005 V6 Mustang 10 11-24-2011 04:58 PM
What gears for my automatic 2012 GT Vert mikona 2011-2014 Mustang GT 16 11-07-2011 01:46 AM
Automatic or later manuel??????? rinfield2004 SVT Mustang 5 10-18-2011 09:31 AM
Went to the drag races today Otlaw80 Pictures and Videos 4 08-08-2011 01:21 PM
04:19 PM
