Help with some transmission questions - Mustang Evolution
Old 12-17-2011, 09:51 AM   #1
V6 stang's Avatar
Have a 99 mustang v6 and I think it's the t5 trans? Idk lol. But when I push the clutch in to start, it's easy to get into reverse. If I crank it, release the clutch while in neutral, then push down on it again, it's hard to get into first and reverse. Why? I have to put it in 1st before I come to a red light, and keep pushed down on the clutch. Because if I put it in neutral and try to put it in 1st at a red light but it takes to long so ppl honk sometimes lol. I have to push pretty hard to get it in. And I have to slam on it to get into reverse. Anyone got any idea? ALSO does anyone know how much estimated trans repair would be for my stang? It's still usable easily but it doesn't slip in nicely like it should and I would like to know how much I should start saving lol... Thanks.
2012 Mustang GT Convertible
Roush Exhaust
2003 Mustang GT (Sold)
Old 12-17-2011, 03:03 PM   #2
I would start with the basics and try adjusting your clutch.
Old 12-17-2011, 03:18 PM   #3
V6 stang's Avatar
Isn't that where you pull your clutch pedal up or somethin?
Roush Exhaust
Old 12-17-2011, 03:48 PM   #4
Yeah basically.here is a good article.
http://www.allfordmustangs.com/forum...ck-clutch.html
Old 12-18-2011, 04:25 AM   #5
What happens when you try to put it into the other gears while at a stop.
Mustangsandiron is offline   Reply With Quote
Old 12-18-2011, 08:59 AM   #6
V6 stang's Avatar
It's a lot easier. It feels like there is a block I have to fight through. A strong restriction. I can push it through in the first gear, and I have to slam it in for reverse, but any other are ok.
Roush Exhaust
Old 12-18-2011, 09:40 AM   #7
It could be the synchros in the trans are worn out.
Old 12-18-2011, 03:32 PM   #8
V6 stang's Avatar
Any idea how much on average it is to repair a trams with issues like that?
Roush Exhaust
Old 12-18-2011, 05:13 PM   #9
Just guessing 1200-1800 but that is all gonna depend on your particular shops.it will probably be even more cause that is just the trans.most people do the clutch while the trans is out.I've never done your particular model but I have replaced a few trans and clutches and I'm no expert.if you are good with a wrench with our help and a Haynes or Chilton it is really not that hard to do yourself.
*But I would still check your clutch adjustment first being it is free and easy.*
Old 12-18-2011, 07:01 PM   #10
V6 stang's Avatar
I've done it before I think. A shop said my syncros and like plastic pieces in my trans was getting worn out? I just wanted to know what y'all thought, or if there was any home remedies lol. I knew it was Gna be alot but damn. Lol.
Roush Exhaust
Old 12-18-2011, 07:09 PM   #11
I'm not sure if it will work in your particular trans but maybe look into some syncro mesh or Lucas makes some real good fluid products that may nurse the life of your trans a little longer.
Old 12-18-2011, 07:48 PM   #12
V6 stang's Avatar
I've heard of changing my teams fluid, would that help?
Roush Exhaust
Old 12-18-2011, 08:16 PM   #13
Probably not.I've heard unless its done regularly it not a good idea.I would just try draining a little and add an additive.there is a high chance this isn't going to help but small price to try before doing a rebuild.
Old 12-18-2011, 08:20 PM   #14
deadsp0t's Avatar
Try slowly raising the clutch pedal while pushing or pulling the shifter slightly to get in gear, slamming will make it worse fast!
That's unimpressive
Old 12-18-2011, 09:05 PM   #15
V6 stang's Avatar
I have tried that, I've pushed all the way down and let up all the way lol. Sometimes it just doesn't want to get in. I have to push/slam it hard to et it in unless I wanna sit at a red light and get honked at for a whole
Roush Exhaust
TR-3650 transmission upgrade? CZYFAST 2005-2010 Mustang GT 22 12-20-2011 04:27 PM
Transmission Questions! V6 stang Pre-2005 V6 Mustang 0 12-16-2011 02:09 PM
Choosing a tranny? Hawk General Mustang Discussion 0 10-08-2011 07:41 PM
Transmission problem carlgator 1979-1995 Mustang GT 1 08-14-2011 09:52 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
11:52 PM
