What years.... - Mustang Evolution
Old 12-18-2011, 08:31 AM   #1
Punks86coupe's Avatar
What years....
I have a 86 coupe and wanted to know what other year of mustangs can I use the front seats and rear seats to fit my 86 for a direct bolt on? Also the double hump trans. Crossmember is the automatic and manual transmission crossmembers the same? Plz help thank you
Punks86coupe is offline   Reply With Quote
Old 12-18-2011, 09:47 AM   #2
I think all the fox seats will work in all the fox stangs but i am not positive. The xmembers are almost the same. One is mounted a little forward in the car than the other.
Mustangsandiron is offline   Reply With Quote
Old 12-19-2011, 05:09 PM   #3
aegischief's Avatar
The seats from any fox body will work. Rear seats need to be from same body style (coupe, vert, hatch). The trans cross member is same for auto and manual.
aegischief is offline   Reply With Quote
Old 12-19-2011, 07:39 PM   #4
I'm still a little confuse since I got 2 diferent answers for the crossmember
Also can I put newer mustang seats from like the 94 and over mustang for a direct bolt on? Also are the coupe and vert back seats the same?
Old 12-19-2011, 07:43 PM   #5
93slowstang's Avatar
The crossmember is the same between auto and manual. The sn95 front seats will bolt in just fine, not sure about backseats though.
Old 12-19-2011, 08:09 PM   #6
aegischief's Avatar
The front seats from a 94-04 will work hay keep in mind that they are a little wider than fox body seats. Rear seats from 94-04 will jot work without modifications. Coupe and vert rear seats are slightly different.
Old 12-19-2011, 08:17 PM   #7
Thank you for responding I'm concidering puting in newer year mustang seats and I don't wanna drill holes and stuff just wanna bolt on and use lol thanx
Old 12-19-2011, 08:42 PM   #8
aegischief's Avatar
No prob. The fronts will bolt in just fine. It's just the paddig and stiff that will make for a tight fit. Out of luck on the rears though. Completely different design.
Dart Iron Eagle heads deadsp0t 1979-1995 Mustang GT 19 12-23-2011 04:59 AM
Back after 3 years..... Vinnietbird New Member Introductions & Greetings 15 10-13-2011 06:49 PM
Newbee from Aberdeen, Md dansg New Member Introductions & Greetings 10 02-07-2011 07:26 AM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
09:08 AM
