Oily Engine Parts - Mustang Evolution
Old 12-31-2011, 04:16 PM   #1
Oily Engine Parts
What is the best way to clean oily engine parts? I was planning on using Lacquer Thinner and maybe soak them then use some kind of degreaser. Does anyone have a good tips to make my life easier?
MyStang68 is offline   Reply With Quote
Old 01-01-2012, 11:15 PM   #2
sinister07's Avatar
Re: Oily Engine Parts
Lacquer thinner is pretty harsh. I use Castrol purple cleaner followed by really hot water.
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 01-02-2012, 01:39 PM   #3
Thank you for the tips! Will give that a try.
Old 01-02-2012, 03:06 PM   #4
vinnygt's Avatar
I use a citrus degreaser. Can't remember the name but I will post it later when I get home. It works really good. Basically just spray on, wait five minutes, wipe down and gently rinse off. Good as new.
vinnygt is offline   Reply With Quote
Old 01-02-2012, 03:16 PM   #5
Mile high JDF's Avatar
The dealership I used to work at just used brake clean. Worked fine.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-02-2012, 05:21 PM   #6
jhagan1980's Avatar
Simple green works really well.
jhagan1980 is offline   Reply With Quote
Old 01-04-2012, 10:54 PM   #7
etc1006's Avatar
X2 on purple cleaner. I buy it by the gallons. Get a good spray bottle, get it wet, spray liberally with purple. Let sit and rinse, repeat and use a scrub brush on the stubborn areas. I have a cheap parts washer from harbor freight ( was under $40 with a coupon). Its a plastic tub one with basically a small pond pump. You can't use harsh stuff in it because it will eat the pump. It's small enough to use when you are wanting to do a good cleaning on say your brakes when you do pads and whatnot too. When done I pump it out into a jug or two for the next time.
etc1006 is offline   Reply With Quote
Old 01-05-2012, 08:47 PM   #8
Thanks for the tips. I just bought some today!
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
06:57 AM
