How long does it take to reset the on-board computer? - Mustang Evolution
Old 12-31-2011, 09:02 PM   #1
Scrshaw's Avatar
Question How long does it take to reset the on-board computer?
So here's the background on this question.
I have an 01 V6 that has a Dyno tune in it using my SCT X-Cal 2.
My state inspection recently changed they way they do things and now ONLY connect a code reader to the car. It reads the codes, and if there are no problems, you pass. Simple right? Well not so much if you have a custom tune. It fails everything. Not because there is actually anything wrong, simply because it can not read the custom tune.
So I flashed it back to stock and have put over 550 City and Hwy miles on the car. Every time I check the codes It gives me a P-1000 = System not ready. I thought it only took about 250 or so miles to reset the data, what am I doing wrong here?
2001 Zinc Yellow V6 3.8L Coupe
65mm TB & Spacer, K&N FIPK CAI, Trac-loc, 4:10 Gears, Custom tune from Pro-Dyno, LT Headers, H-Pipe, High-flow Cats, Flowmaster 40's, UD pulley's, Upper and lower rear control arms, Drag launch springs, Line-locks, Custom Built 4R70W Trans,2500 RPM Torque Converter, Trans Cooler, 190 LPH fuel pump
Scrshaw is offline   Reply With Quote
Old 12-31-2011, 09:04 PM   #2
Re: How long does it take to reset the on-board computer?
you need to reflash the system after installing the stock tune....so pop that neg cable off for a couple minutes....then you'll need to do a drive cycle...it's under a hundred miles
SonicBoom239 is offline   Reply With Quote
Old 12-31-2011, 09:18 PM   #3
Scrshaw's Avatar
I did that after I re-flashed it. left the cable off for about 45 minutes because I replaced the coil, plugs an wires while I was at it.
Old 01-01-2012, 12:36 AM   #4
reflash it again and go for another drive cycle...it shouldn't take more then 100 miles...
Old 01-01-2012, 12:42 PM   #5
Scrshaw's Avatar
ok, I'll give that a shot.
Thanks.
Long Tube/SCT Tuner Install Done!!! NOW TIME FOR MORE!! CodyNelson 1996-2004 Mustang GT 13 10-18-2011 12:02 PM
Building a computer tower... input needed jimmy_beaner The Bar 52 09-06-2011 09:48 PM
02:15 AM
