Unlock remote not working? Help - Mustang Evolution
Old 01-08-2012, 06:38 PM   #1
98projectpony's Avatar
So I have a 98 v6 and recently my remote suddenly stoped working so now I have to unlock with key..I tried replacing the batteries but nothing ..do you think age got to it or what? And were is the security receiver in the car located just in case I need to replace it
98projectpony is offline   Reply With Quote
Old 01-08-2012, 06:45 PM   #2
aegischief's Avatar
Is there anything else acting weird or not working?
aegischief is offline   Reply With Quote
Old 01-08-2012, 07:22 PM   #3
Well I had taken my dome light out a month back because it would stay on....ohhh and the night before it went out when I got out of my car about to shut the door my locks did something and unlocked then locked and I didn't touch my remote but I didn't think anything of it
Old 01-09-2012, 07:56 PM   #4
aegischief's Avatar
Could be the electronic control module.
Old 01-09-2012, 07:58 PM   #5
What do you suggest I do
Old 01-09-2012, 08:02 PM   #6
aegischief's Avatar
Check to make sure that the ground wire is making good contact. I had a similar problem in my F150 with my key fob not working, auto head lamps not working and what not. Ended up being a broken ground wire.
Old 01-09-2012, 08:04 PM   #7
Lol I dont want to sound stupid but do you know were I can find the ground
Old 01-09-2012, 08:05 PM   #8
Blogger
99ford's Avatar
First how fresh is the battery?
Old 01-09-2012, 08:08 PM   #9
Not sure iv had the car a year now and haven't messed with it..I recently got a sound system would that mess with the battery? It still starts fine and runs
Old 01-09-2012, 08:17 PM   #10
Blogger
99ford's Avatar
It shouldn't unless it was installed wrong. The battery can do funny things. It's probably worth getting a new one.
But if you did everything right there shouldn't be a problem. Or took it to a shop.
Old 01-09-2012, 08:19 PM   #11
It was a professional installation so I'll try a new battery
Old 01-09-2012, 08:30 PM   #12
Blogger
99ford's Avatar
I didn't read that well. You could check the ground- it should be under the hood-up front. It's just a dull wire. Just Google it, sorry for the vauge answer, but I can't think of how to describe it.
Maybe try checking the fuses. The battery should be fine as long as there is no hesitation. If those fail then I'd go ECM.
Again it won't hurt to replace it though. Costco has a good battery for not much money. It's worth a shot.
Old 01-14-2012, 10:38 PM   #13
Smokedog's Avatar
My buddy's stang fob just stopped working for no apparent reason one day also. We fixed it by removing both battery cables and touching them together about 30 seconds to reset the pcm. And its been working since.
Smokedog is offline   Reply With Quote
Old 01-15-2012, 10:12 AM   #14
I might try that it won't mess anything up will it?
Old 01-15-2012, 10:27 AM   #15
DaBluedude's Avatar
Ur sound system could be involved or the module but with what the doors did it sounds like you unprogrammed your remote somehow. Try the reprogramming sequence (available via google search) and see if that fixes it. (Note, u need both keys to do this... if not, I'm pretty sure your looking at dealership time.
2003 Mach 1
Old 01-15-2012, 01:18 PM   #16
Smokedog's Avatar
No. What you're doing is just discharging all the capacitors. Just make sure they are both disconnected when you touch them together.
Unlock remote not working? Help 98projectpony General Mustang Discussion 0 01-08-2012 06:36 PM
Remote logging session Black5.0 2011-2014 Mustang GT 5 11-16-2011 07:43 PM
Head unit not working..... mcvicar04 1996-2004 Mustang GT 20 07-29-2011 09:08 AM
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 01:44 PM
Remote door locks jhagan1980 1979-1995 Mustang GT 9 06-28-2011 12:08 PM
06:13 PM
