Battery light - Mustang Evolution
Old 01-14-2012, 11:43 AM   #1
Siendly22's Avatar
Battery light
Why would the battery light flash when the gas pedal is pressed hard and goes off when normal pressed?
Siendly22 is offline   Reply With Quote
Old 01-16-2012, 04:39 PM   #2
94 Mustang GT's Avatar
Sound like you might have an alt issue. It could possibly be putting out too much voltage to the battery. Or the voltage regulator (which I believe is in the alt) could be bad. Easy way to check. Hook a digital multi meter to the battery. Should get about 14.5-14.9 volts. Will the issue happen if the tranns is in neutral?
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 02-24-2012, 10:36 PM   #3
Siendly22's Avatar
I replace my alternator to a new one. You are right is the alt. Because I change the battery first before i get a new alt , but still below 13 volts show On the meter voltage.
Old 02-24-2012, 11:57 PM   #4
irishn8's Avatar
Running its still 13v? That's not right, should be above 14.2 at the very least. What amp alt did u get?
Old 02-25-2012, 01:28 PM   #5
Siendly22's Avatar
Now I change the alternator and the battery , I have a normal 14.5 volts.
Old 02-25-2012, 05:01 PM   #6
irishn8's Avatar
Perfect
Old 02-25-2012, 05:20 PM   #7
Siendly22's Avatar
Perfect
+1
battery leaking Robbie94gt 1979-1995 Mustang GT 13 12-19-2011 05:02 AM
Marker light nickysixx 1996-2004 Mustang GT 2 12-07-2011 11:23 PM
Battery Eturner 1996-2004 Mustang GT 16 11-20-2011 11:20 AM
Time for new battery? ovyallday89 2005-2010 V6 Mustang 2 10-27-2011 09:40 AM
O/D light blinking BigB227 1996-2004 Mustang GT 4 10-15-2011 04:23 PM
02:56 AM
