NEED HELP ! - Mustang Evolution
Old 01-15-2012, 04:04 PM   #1
GTtopgear's Avatar
NEED HELP !
I have a 85 Camaro Iroc z. The car wouldn't start so I changed the alternator and the wiring ad had the car jumped, start and ran for 3 min and then died. Won't start again. Any ideas guys? I know it's not a mustang but it's American !
02 GT : LT headers, H pipe, Cat back, 80mm TB, Intake, Strut tower bar, lightweight pullies All BBK, drilled and slotted rotors, Clear headlights, Eibach Pro Kit, Hid kit for both head and fog, chin spoiler,18' chrome 2010 GT wheels with nitto tires
GTtopgear is offline   Reply With Quote
Old 01-15-2012, 08:35 PM   #2
what is it doing?just clicking?you need to have the battery and starter tested
---------- Post added at 09:35 PM ---------- Previous post was at 09:34 PM ----------
there is a section for general car discussion btw.
Old 01-15-2012, 08:36 PM   #3
MiGT01's Avatar
Re: NEED HELP !
If you changed the alternator than it sounds like the cells in the battery are shot. Even a charge will only be good for a few days. Also check your ground wires.
01 Black Beauty GT
Eibach pro kit,Tokico shocks/struts,BBK CAI,75mm TB/ Plenum,4.10 FRPP gears,BBK o/r X pipe,Magnaflow Catback,SCT Tuner running 91 Tune,Bama Tunes for Life Member,RAM HD Clutch,BM shifter with MGW "GT" knob,AM smoked Headlights/Sylvania zXe bulbs,VHT smoked tails/3rd brake,Redtop Optima,Mach 1 grille delete,Mach 1 chin spoiler,BULLITT Pedals,20% tint all round,4.6 High Performance Badges
MiGT01 is offline   Reply With Quote
Old 01-16-2012, 12:01 AM   #4
GTtopgear's Avatar
Its a brand new battery. It sometimes clicks and sometimes just nothing
Old 01-16-2012, 05:19 PM   #5
MiGT01's Avatar
Re: NEED HELP !
Was it the right alternator? Refurb or new? What about the voltage regulator?
01 Black Beauty GT
Old 01-16-2012, 05:40 PM   #6
im going with starter or selinoid.autozone will test
Old 01-17-2012, 08:36 AM   #7
GTtopgear's Avatar
The weirdest thing worked. I changed the spark plugs and used sea foam. I'm pretty sure the sea foam worked cuz there was probably moisture in the gas. Now engine coolant is soaked on the drivers side floor mat an smoke is coming threw the air vents. I'm thinking heater core?
11:15 AM
