Noz bottles - Mustang Evolution
Old 01-18-2012, 01:51 PM   #1
shsfresh87's Avatar
Region: West Virgina
Noz bottles
Where is a good place for the noz bottle? Ive seen em under the hood, under the passenger side seat, and even the trunk, n ur opinion, what's the best, also is it better to have a button that u press with ur finger or use the 'wet' system which activates wen ur pettle is full throttle
shsfresh87 is offline   Reply With Quote
Old 01-18-2012, 01:56 PM   #2
Eturner's Avatar
I would say mount it in the trunk and use a button!.. Don't use a WOT setup!...
Old 01-18-2012, 05:23 PM   #3
Re: Noz bottles
I think you need to learn about "noz" before attempting to put it on your car...
Seriously...
Step away from the "noz"
Old 01-19-2012, 07:24 AM   #4
shsfresh87's Avatar
Im not gonna get it til I build my engine, I just wanna know for down the road
Old 01-19-2012, 09:29 AM   #5
Meansaleen's Avatar
Seriously...
+1
Meansaleen is offline   Reply With Quote
Old 01-19-2012, 09:38 AM   #6
shsfresh87's Avatar
U do know that noz and nos are the same thing thing right?
Old 01-19-2012, 09:42 AM   #7
93slowstang's Avatar
Well NOS is a company that makes N2O or "nitrous" systems. Noz is something I would expect a ricer to say. Lol
Old 01-19-2012, 11:32 AM   #8
DaBluedude's Avatar
+1.
2003 Mach 1
Old 01-19-2012, 03:49 PM   #9
shsfresh87's Avatar
So ur sayn there is a right way to say noz? So wat if I said Mustang instead of stang? Is that wrong 2? Is there only 1 way to pronounce potatoe?
Old 01-19-2012, 03:57 PM   #10
Nos stands for nitrous oxide systems, not nitrous.
---------- Post added at 04:57 PM ---------- Previous post was at 04:55 PM ----------
As to your original question I would run a wet kit with a rpm window switch and put the bottle in the trunk.
Old 01-19-2012, 05:26 PM   #11
DaBluedude's Avatar
Yes. Nos is nitrous oxide system, nitro is for nitro-meth systems, and N2O, di-nitrogen mono-oxide, or nirtous are references for what you are talking about. Run whichever system you want, get it tuned properly and mount them in the trunk to the floor or to the backs of.the rear seats.
2003 Mach 1
Old 01-19-2012, 05:50 PM   #12
shsfresh87's Avatar
Nitros oxide and nitros are the same thing
---------- Post added at 07:50 PM ---------- Previous post was at 07:49 PM ----------
Nitrous
Old 01-19-2012, 06:29 PM   #13
Filibuster
Poe-tay-toe!! Not Pah-tot-toe!!
Nitrous not NOS!!..
Lol
XXSTEVEO66 is offline   Reply With Quote
Old 01-19-2012, 06:53 PM   #14
Re: Noz bottles
He said NOZ...
I agree with above, window switch and wet kit.
BTW, a wet kit injects both Nitrous (NOZ as you prefer) and fuel (gasoline) into the intake whereas a dry kit injects only Nitrous (or NOZ). Placement of the nozzles, pressure, and fuel capabilities are your controlling factors in deciding what to do. For me, a wet kit is a safer kit as you are compensating for the additional fuel needed by supplying your own fuel. Others prefer a dry kit and simply tune the car to adjust itself.
And a window switch is where you set the solenoids to activate at XXXX Rpm's and close at XXXX Rpm's, basically giving you a "window" of sorts in which the extra power is produced. The nice thing is it will give you a safe shift period and launch period without excess pooling in the intake if you set these parameters correctly. I've seen more than my handful of Nitrous (sorry...NOZ) backfires and explosions, they are not fun.
Also, if you aren't budgeting to spent $600 minimum for a safe, high quality setup then do more research. The little pieces are what make the difference.
Yes, I've heated bottles on stoves and with blow-torches, but a damn bottle heater wired into the car is really the safest thing out there.
Old 01-19-2012, 07:14 PM   #15
shsfresh87's Avatar
Blow torch? Badass lol
Old 01-19-2012, 07:29 PM   #16
Brett Greene's Avatar
Seriously...
HAHAHAHA yess
Brett the best Greene
Brett Greene is offline   Reply With Quote
10:26 PM
