big question - Mustang Evolution
Old 02-02-2012, 03:20 PM   #1
Punks86coupe's Avatar
big question
Hey peeps just a quick question I have a 86 coupe with a 7.5 rear end I bought a 8.8 diferential out of a 91 mustang. I heard from someone that . The 91 diferential might be to big just wanna know if this is true. I thought all foxbody diferentials were the same in lenght. Any advice b4 I install it?
Punks86coupe is offline   Reply With Quote
Old 02-02-2012, 06:04 PM   #2
aegischief's Avatar
They are the same size as far a mounting goes. Will bolt right in no problems.
aegischief is offline   Reply With Quote
Old 02-02-2012, 06:45 PM   #3
93slowstang's Avatar
+1
Old 02-02-2012, 09:14 PM   #4
My thing is if it's the same length axle to axle as the 7.5
Old 02-02-2012, 09:19 PM   #5
Yes, they are the same length.
---------- Post added at 10:19 PM ---------- Previous post was at 10:18 PM ----------
Like aegis chief said, it's a straightforward swap.
Old 02-02-2012, 10:03 PM   #6
aegischief's Avatar
I did this exact swap in my 83 GT I used to have. Took a friend and I a little less than 2 hours to swap from jacking it up to test drive.
Length is exactly the same. Mounting points for shocks and control arms are exactly the same.
Old 02-02-2012, 10:50 PM   #7
Thanx guys this relieves some stress I had. Thank you for the great advice will do the swap this weekend thanxx
Old 02-03-2012, 02:42 PM   #8
aegischief's Avatar
While ur at it. I would replace the upper control arm bushings an the lower control arms. Jut a thought.
Old 02-03-2012, 06:30 PM   #9
Yes I already have the rear upper and lower arms tubular with poly bushings thanx
Got a body question? 1234 1996-2004 Mustang GT 11 01-01-2012 12:13 PM
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 09:11 PM
Please Help support me in "The Big Climb" Renegade 800 The Bar 0 11-16-2011 08:51 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 12:54 PM
Off Topic Question - Oil Weight illestdomer2005 Pre-2005 V6 Mustang 7 09-09-2011 09:26 AM
05:06 AM
