99 v6 no start - Mustang Evolution
Old 02-26-2012, 07:20 PM   #1
Region: New Mexico
99 v6 no start
I have a 99 v6 mustang that i just completed a motor swap on. The original motor was knocking and I replaced it with a used motor. I used the original harness from the car but used the injectors and all sensors supplied from the "running motor" I purchased. The theft light does not flash while I crank the vehicle over. I have spark and pressure at the fuel rail. Not exactly sure on the pressure at the moment but it does have pressure when i relieve the valve with a screw driver. The motor will start and run when I carb and choke the throttle body but will not run on its own. I have 12 volts at the injectors but not sure exactly how to check for my pulse!? I have gone through all of the fuses with a test light and there where a couple on the fuse block under the dash that didnt have power but I dont have info on which fuses they are. The car did run before I swaped the engine. I have made sure that my grounds are good and all connectors are in. any advice on this would be appreciated, Thank YOu
silveradoman83 is offline   Reply With Quote
Old 02-27-2012, 07:52 PM   #2
Mustangguy0202's Avatar
Did you try turning the key to the on position and listening to make sure the fuel pump turns on?
Mustangguy0202 is offline   Reply With Quote
Old 02-27-2012, 07:59 PM   #3
irishn8's Avatar
Engine code(s)?
Brand New JLT cold air intake for 05-09 v6 stamg saxxx Mustang Parts for Sale and Wanted 9 03-12-2012 08:56 PM
Future GHI Green Mustang Owner wanting to put the Black 2008 Bullitt Wheels on a V6 Gtzzoom Mustang Wheels & Tires 2 03-08-2012 02:00 PM
Ellie :: 2011 Ford Mustang 04TRV6 Member Garages 2 03-08-2012 06:49 AM
2002 V6 mustang cats? Rouse Pre-2005 V6 Mustang 43 03-03-2012 06:58 AM
PCV OR NO PCV ?????????? rick978 1979-1995 Mustang GT 13 02-24-2012 11:42 AM
02:20 PM
