Smog pump delete - Mustang Evolution
Old 03-06-2012, 08:57 AM   #1
Jesse Bach's Avatar
Smog pump delete
Is removing the smog pump out of a 94 gt a good idea or should I just keep it in
Jesse Bach is offline   Reply With Quote
Old 03-06-2012, 10:15 AM   #2
NeedSomeMods's Avatar
You won't really see any gains from removing it. If it's working properly, it's best to leave it. Especially if you still have cats..
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 03-06-2012, 10:18 AM   #3
McNassty's Avatar
What if your not running cats? I have shorty headers, o/r x-pipe running into flowmaster 40's w/o cats and I've been looking at the smog pump deletes. What are the benefits?
McNassty is offline   Reply With Quote
Old 03-06-2012, 10:32 AM   #4
Titus Wadicus
svtlx's Avatar
Re: Smog pump delete
are you already running an egr delete? if u plan on running a blower one day "centri" u should just leave it on. its not really hurtn anything either or. if u get a full horse from taking it off ill be surprised.
but hell, take it of if u r just looking for something to do.
or u could take it apart and gut it... i did that to mine and then filled it with wheel bearing grease. that way its just a pulley with no real resistance, and u dont have to worry bout it lockn up later.
dats just my opinion though
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-06-2012, 12:21 PM   #5
The main reasons people remove is for high HP applications and for a "cleaner look". If you don't have cats, then the smog pump isn't really doing much, so you might as well not have it.
2000 V6 - RIP
The '94 -
Old 03-06-2012, 01:28 PM   #6
McNassty's Avatar
Thanks guys, I really like the 'gut it' idea and I do plan on installing a s/c by next year.
Old 03-06-2012, 05:24 PM   #7
Titus Wadicus
svtlx's Avatar
sum centrifugal superchargers require u to have the pollution pump in place cause of how the pulleys run. and others like my powerdyne r set-up so itsa pain in da *** to try to use a by-pass pulley. so i ended up giving a guy 10 bucks for his pump. and putting it on, cause mine had been looong gone lol.
when u start blower shop'n u will see wut im talkn bout.
Old 03-06-2012, 07:57 PM   #8
McNassty's Avatar
Thanks, I wanted to whipple mine but I talked to a friend and he told me that if I wanted to stay sleeper looking than the whipple was out cause I'd need a new hood. So would gutting my smog pump work with the other s/c's?
Old 03-06-2012, 08:04 PM   #9
Titus Wadicus
svtlx's Avatar
absolutley... just ask the company u get it from, they will tell u if u need a actual pump or if u can get away wit a pulley... or nuthn at all. but if u already got a pump just gut it cause its free...
---------- Post added at 10:04 PM ---------- Previous post was at 10:02 PM ----------
once dat bov goes woooosh!!!! u wont care bout the whole sleeper thing anymore...lol.
Old 03-06-2012, 08:11 PM   #10
McNassty's Avatar
Oh no, I love the s/c sound, nothing like it or the feel, except when you dust a $60,000 ride in a '95 that cost me $6,000 and another $8,000 in the motor. The surprised look on their face is priceless!
kenne bell boost a pump syrupsaleen Saleen & SMS Mustang 128 04-12-2012 11:26 AM
Walbro 255lph Fuel Pump CodyNelson Mustang Parts for Sale and Wanted 3 03-27-2012 04:55 PM
new fuel pump Robbie94gt 1979-1995 Mustang GT 6 03-01-2012 10:29 AM
Spoiler delete haters SD06stanger 2005-2010 Mustang GT 75 02-29-2012 10:19 PM
Dual Exhaust Conversion & Smog Soccerluvr4 2005-2010 V6 Mustang 2 02-29-2012 10:11 PM
03:33 PM
