0-60 machine - Mustang Evolution
Old 03-07-2012, 07:33 PM   #1
DA BEAST7524's Avatar
0-60 machine
What mods are needed to make a 0-60 machine? Basically street light to street light I want to accelerate fast but I don't want 1/2 mile type endurance.
What mods would be good if you were looking to make your car one of these?
DA BEAST7524 is offline   Reply With Quote
Old 03-07-2012, 07:36 PM   #2
Titus Wadicus
svtlx's Avatar
Re: 0-60 machine
well, 4.10, 4.27, 4.56 gear will get u sum good light to action... but u will prolly lose ur license n the process..lol
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-07-2012, 07:36 PM   #3
Yeah I was just thinking hypothetically. I probably won't do any of this
Old 03-07-2012, 08:30 PM   #4
BaSohol's Avatar
Get 410s you'll hang with almost any car 0-60 on the street
2007 Ford Mustang GT 5spd
Old 03-07-2012, 08:32 PM   #5
Wow. I didn't know that gears had that much of an effect on this
Old 03-07-2012, 10:43 PM   #6
gears are one of the best performance/acceleration mods u can do. imo
Old 03-08-2012, 07:54 AM   #7
Mustang240's Avatar
Sweet I wanna do this for my v6.. Anyone know how much they roughly cost? And will it void my warranty.
Mustang240 is offline   Reply With Quote
Old 03-08-2012, 08:24 AM   #8
shsfresh87's Avatar
Region: West Virgina
Thats what I plan on doing to my stang, im gonns get 4:10s, cold air induction, Roots supercharger, racing cam, stuff like that so im quick outa the gate
shsfresh87 is offline   Reply With Quote
Old 03-08-2012, 08:27 AM   #9
Rapinator126's Avatar
Im putting 410s in my roush today. Will be getting started soon.
Rapinator126 is online now   Reply With Quote
Old 03-08-2012, 09:16 AM   #10
Mustang240's Avatar
That's sikk!! How much r they gonna cost u?
Old 03-08-2012, 09:29 AM   #11
BaSohol's Avatar
I got my gears at latemodel for 140 shipped
Gear oil at pepboys 70 dollars
Install kit 30 dollars at AM ( only this kit for low mileage cars, other wise get the bearing kit )
And pro install 250 dollars @deans performance
So 490 is about what I paid
Old 03-08-2012, 09:33 AM   #12
Mustang240's Avatar
Wow that's expensive. Will it really make a difference? I have a 2012 v6, also will it void warranty?
Thnks man
Old 03-08-2012, 06:20 PM   #13
sinister07's Avatar
Re: 0-60 machine
Performance mods will only void the warranty IF the dealer can prove the mods caused a failure. Of course, there are crooked dealers that will try just about anything to get out of warranty work, including bullying customers into believing their mods voided the car's entire warranty.
As far as gears are concerned, $490 installed is about right. The parts are not very expensive, but the specialized labor is what costs you. It is not a job for the weekend shade tree enthusiast to try at home.
We just put 4.10s in my daughter-in-law's '88 GT. We just swapped the whole rearend. I can tell you, it made a HUGE difference in the performance!
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 03-08-2012, 07:36 PM   #14
When I did my gears for the first time I actually thought it wasnt to bad.IMO as long as you are mechanically inclined and have a good understanding with working on critical measuring.you will be fine.also having access to a few special tool and you should be able to handle them.but if you can find a reputable shop to do the install for under 300$ labor then it may be worth it. Like I said this is just my opinion.
Old 03-08-2012, 07:48 PM   #15
sinister07's Avatar
Re: 0-60 machine
I have done them at home, too. After I bought a hydraulic press, a dial indicator, a magnetic mount, shims, a pinion depth gauge, and a set of set-up bearings, I could have paid a professional to do it.
Just my opinion, gears are like dentistry- don't do it yourself.
2003 Mach 1
Old 03-08-2012, 07:49 PM   #16
BaSohol's Avatar
Ya it's not hard, just the tools needed and helps to have lift, I did them my self before, but this time around I didnt have a garage or a other car to drive, and I can afford to pay someone 250 to do it so ehh
Old 03-08-2012, 08:05 PM   #17
250 is worth it.
I did mine without a lift or press.the bearings can be removed with a good puller and or bearing seperator.the master install kit comes with shims.basically if you can get a micrometer and dial indicator it can be done.
I'm not disagreeing with you at all.I have done a lot of rolling mill and big motor gearbox alignments through my current and previous jobs.so this kind of work I am pretty used to.so me personnaly didn't have to much of a problem.plus I am just the diy kind of guy.
Old 03-08-2012, 11:09 PM   #18
sinister07's Avatar
Re: 0-60 machine
I certainly meant no disrespect. It sounds as though you are no newcomer to precision work.
2003 Mach 1
Old 03-08-2012, 11:16 PM   #19
I know u didn't its cool.I was kinda explaining me losing my virginity to the rear end.Lmao. eek
Old 03-09-2012, 09:25 AM   #20
Mustang240's Avatar
Lmao. I guess that's one way to lose ur virginity.
I think if I change the gear to 4.10 I lose the warranty since its not a ford approved gear.
Old 03-09-2012, 11:11 AM   #21
Probably.they might have to do it
« Suspensiom | Gears »
sick! fastest mustang production ever.0-60 under 1 sec dreamstang Pictures and Videos 13 03-11-2012 08:02 PM
Sewing machine t0t4lbl4ck0ut 1996-2004 Mustang GT 4 10-08-2011 08:08 AM
Best technique for 0-60 off the line? Deflep Shelby Mustang 10 09-29-2011 11:35 PM
09:14 AM
