Need help with Hid kit - Mustang Evolution
Old 03-12-2012, 03:10 PM   #1
Noerrors8's Avatar
Please if somebody can give me. Step bye step on how to do these I'd much appreciat it
Noerrors8 is offline   Reply With Quote
Old 03-12-2012, 03:31 PM   #2
Rmag's Avatar
There is a video on how to do it on xenonsupply.com step by step
Rmag is offline   Reply With Quote
Old 03-12-2012, 03:47 PM   #3
BaSohol's Avatar
Plug em in? I installed my fog lights and it was 100 percent plug and play, did you get relays with your kit? Btw how much?
2007 Ford Mustang GT 5spd
Old 03-12-2012, 03:50 PM   #4
Noerrors8's Avatar
The video they have aren't the same parts that I have it's a different ballast and cables are not the same
---------- Post added at 03:50 PM ---------- Previous post was at 03:48 PM ----------
And they did not give me a relay harness what I have u guys in the pic is what they gave me
Old 03-12-2012, 03:54 PM   #5
BaSohol's Avatar
Ok idk what those positive and negative terminals off the bulbs are for, I assume for some relay but check you tube cause it is literally a plug and play setup
---------- Post added at 04:54 PM ---------- Previous post was at 04:53 PM ----------
Stock head plug to adapter plug to ballast to hid bulb
Old 03-12-2012, 04:10 PM   #6
Noerrors8's Avatar
I know I've been checking YouTube and none of them look the same ao idk how mine works
---------- Post added at 04:10 PM ---------- Previous post was at 03:54 PM ----------
When I plug everything together there's still. A missing plug or adapter
Old 03-12-2012, 04:24 PM   #7
BaSohol's Avatar
Plug everything in and take a pic
Old 03-12-2012, 04:31 PM   #8
Las0mbra's Avatar
I'll find a video!
---------- Post added at 04:31 PM ---------- Previous post was at 04:27 PM ----------
Couldn't find a vid but I found a good install article!
https://www.ddmtuning.com/support/in...wnloaditemid=3
Old 03-12-2012, 04:44 PM   #9
Noerrors8's Avatar
Here is the pic idk where the ballast red cable goes
Old 03-12-2012, 04:45 PM   #10
Noerrors8's Avatar
Am I missing anything ?
ID:	43343   Click image for larger version
Old 03-12-2012, 04:47 PM   #11
Las0mbra's Avatar
Well, that side always goes to power. Is there anything in the kit that plugs in to it?
---------- Post added at 05:47 PM ---------- Previous post was at 05:46 PM ----------
I got it! Do you see the wires that have red and black spade connectors?
Old 03-12-2012, 04:56 PM   #12
BaSohol's Avatar
The red cable out of the ballast is for the stock harness, normally there is an adapter In between the ballast and stock wire harness
Old 03-12-2012, 05:01 PM   #13
BaSohol's Avatar
I think this is how is goes and you wont need to use the other wired if it is indeed for a relay harness but what kind of bulb is this for?
Old 03-12-2012, 05:29 PM   #14
Noerrors8's Avatar
That's the thing I believe I don't have a relay harness does this mean I must get one
---------- Post added at 05:29 PM ---------- Previous post was at 05:29 PM ----------
And yes I See the wires
Old 03-21-2012, 09:23 AM   #15
Noerrors8's Avatar
Got it Ty guys
Old 03-21-2012, 09:37 AM   #16
BaSohol's Avatar
And God said "let there be light"
Old 03-21-2012, 06:01 PM   #17
Noerrors8's Avatar
And there was to much light lol
Old 03-23-2012, 09:36 PM   #18
fultonboy09's Avatar
And it was good!
fultonboy09 is offline   Reply With Quote
Old 03-23-2012, 10:30 PM   #19
Ap0cLFC's Avatar
lol nice guys^^^
Ap0cLFC is offline   Reply With Quote
Old 03-29-2012, 03:09 PM   #20
Siendly22's Avatar
Did you put relay on your hid kit?
Siendly22 is offline   Reply With Quote
Old 03-31-2012, 10:02 PM   #21
Noerrors8's Avatar
Yes I had to buy one
Old 03-31-2012, 11:50 PM   #22
Siendly22's Avatar
I have relay wiring harness kit included , but I never install it. It works without the relay, but makes me worry. I don't know if it's okay without the relay or not though.
Old 04-01-2012, 11:24 AM   #23
Noerrors8's Avatar
You should be fine as long as the lights get the current it's ok
2012 v6 Mustang Help.. What to do with it? xBoyDough 2011-2014 V6 Mustang 17 03-16-2012 12:01 PM
02 transmission help Nate98stang 1996-2004 Mustang GT 28 03-15-2012 11:28 PM
Post brake pad install help silvr002001 1996-2004 Mustang GT 7 03-12-2012 06:26 PM
Need cams 1lowGT 1996-2004 Mustang GT 4 03-12-2012 05:09 PM
Help Me Spend My Tax Return jjsg09 1996-2004 Mustang GT 11 03-12-2012 05:07 PM
08:10 AM
