2000 musatng gt - Mustang Evolution
Old 12-19-2007, 05:13 PM   #1
2000 musatng gt
I have a 2000 mustang gt. I have an off road h-pipe, k&n filter, and diablo sport programmer. My car keeps running rich and throwing up a code for manufacture air monitor control. Can some help me with my problem? Thanks
Hotrod383 is offline   Reply With Quote
Old 12-19-2007, 05:45 PM   #2
hottcobra's Avatar
Re: 2000 musatng gt
are you talking about the mass air flow sensor?
Old 12-19-2007, 06:33 PM   #3
rocknbronco's Avatar
Re: 2000 musatng gt
Sounds more like a O2 issue how many miles you got on it has it been tuned up including O2 sensors lately????
rocknbronco is offline   Reply With Quote
Old 12-19-2007, 06:39 PM   #4
Re: 2000 musatng gt
Do you have the actual code it is throwing? Wording sounds like the one a KB cobra was throwing here with an O2 sensor was melted through...
Old 12-19-2007, 06:49 PM   #5
Re: 2000 musatng gt
autozone will run the codes free for you if you need it done, that can help you narrow down the sensor or issue.
Old 12-20-2007, 10:04 AM   #6
Re: 2000 musatng gt
I have replaced the tps, air idle control, mass air flow, and the upstream o2 sensors. The rear sensors are turned off. Two of the codes are p1132, p1152. Ill check for other two. Also the car jumps while driving.
Old 12-20-2007, 10:20 AM   #7
Re: 2000 musatng gt
Those are both 02 Sensor codes.
Here are possible causes
Electrical
- Short to VPWR in harness or HO2S
- Water in harness connector
- Open/Shorted HO2S circuit
- Corrosion or poor mating terminals and wiring
- Damaged HO2S
- Damaged PCM
Fuel System
- Excessive fuel pressure
- Leaking /contaminated fuel injectors
- Leaking fuel pressure regulator
- Low fuel pressure or running out of fuel
- Vapor recovery system
Induction System
- Air leaks after the MAF
- Vacuum Leaks
- PCV system
- Improperly seated engine oildipstick
EGR System
- Leaking gasket
- Stuck EGR valve
- Leaking diaphragm or EVR
Base Engine
- Oil overfill
- Cam timing
- Cylindercompression
- Exhaust leaks before or near the HO2S(s)
Source -> http://home.comcast.net/~miracerros/...wertrain_2.htm
Old 12-20-2007, 10:25 AM   #8
slostang's Avatar
Re: 2000 musatng gt
Do you have a tune, new MAF, or CAI on the car? If so that may be the cause of your code. If you have a datalogger you can log your fuel trims and see how far off they are. If the other one is near %20 off its probably not a bad sensor and needs a tune adjustment. If the other trim is <10% off its probably a bad sensor, exhaust leak, or vacuum leak.
slostang is offline   Reply With Quote
Old 12-20-2007, 10:28 AM   #9
Re: 2000 musatng gt
He has a predator...so datalogging is a little bit of a PITA.
He has an off road h-pipe, k&n filter, and diablo sport programmer....and has replaced the tps, air idle control, mass air flow, and the upstream o2 sensors.
Based on the causes I listed, it sounds like it could be a vacuum leak somewhere or an exhaust leak close to the upstream O2 sensors....or, somehow the O2 harnesses got damaged.
Homeboy with the 2.8 KB had his installed sitting on top of the EGR tube and they melted. He car throws the 1132 periodically. Side note...The shop that did the work also just set the top tranny bolt in the hole...it fell at cody's feet while on the lift.
04' 3.9 Musatng engine problem video!!! Zebs5408 Pre-2005 V6 Mustang 5 02-04-2010 07:40 AM
2000 v6. what should I do first? BMustang1 Pre-2005 V6 Mustang 23 03-30-2009 04:53 PM
2000 3.8 into a 95 66fstbck Pre-2005 V6 Mustang 14 02-08-2007 07:44 PM
My new 2000 V6 Ibanezplayer272 Pictures and Videos 21 02-26-2006 10:26 AM
AND we have 2000!!! Zim The Bar 23 03-29-2005 02:25 PM
06:07 AM
