bad gas... octane booster??? - Mustang Evolution
Old 04-20-2012, 11:34 PM   #1
DaBluedude's Avatar
So i got a bad tank of gas and the car is pinging down low and at wot. i have never used an octane booster but I've got auto x on Sunday. anyone recommend anything?? i think i only need to raise it a few points...
2003 Mach 1
Old 04-20-2012, 11:41 PM   #2
Stang.racr's Avatar
I would
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 04-21-2012, 06:41 AM   #3
I use octane booster quite often. I use them like every 8th fill up to clean out my system. These boosters will improve the fuel system and help remove the pinging sound your hearing. With that said, where do you normally fill up at? What octane level do you normally use?
SNK3BTE04 is offline   Reply With Quote
Old 04-21-2012, 11:17 AM   #4
DaBluedude's Avatar
91 is all i can get. i bought a tank from a different station last night and the car was running like **** in a few miles. what octane booster do you use?
2003 Mach 1
Old 04-21-2012, 06:32 PM   #5
I use the 104 brand normally. I use Sunoco gas or Shell for 93 octane. Sucks 91 is the highest u got out there.
Old 04-21-2012, 08:22 PM   #6
Re: bad gas... octane booster???
Any of those octane boosters you buy won't do crap for your car. They're a gimick...expensive...but don't work.
Best best is to drain and start over, other option is to add some torco to fix the issue. Not cheap either way but definitely the best way.
Look on the bottle and see how much it will take to actually raise the octane rating of 15 gallons of gas. You'll spend $100 for 1 point raised in octane rating.
Old 04-21-2012, 08:30 PM   #7
mi03svt's Avatar
This sounds about right from what i have read about the octane boosters too! They sound like they are more for peace of mind rather than actually do any good for your car.
mi03svt is offline   Reply With Quote
Old 04-21-2012, 11:26 PM   #8
DaBluedude's Avatar
Had a highway trip with it today and i set the tune to run a little less timing. burned off most of the tank no problem. ill get some good stuff in it asap.
2003 Mach 1
Old 04-23-2012, 04:46 AM   #9
I don't use it for octane booster considering I always use 93 anyways.... I do use it to clean out my system which does help.
Old 04-24-2012, 07:23 AM   #10
Send a message via AIM to Borii
Correct. Octane booster raises barely a point. You could drain it or drive a little and keep filling until its all 91. Sorry this happened to ya'
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 05-13-2012, 06:33 AM   #11
Gobabygo67's Avatar
I use the see through bottle of 104 octane booster it helps me out pretty good they sell it at autozone and some advanced auto parts store
Gobabygo67 is offline   Reply With Quote
Old 05-15-2012, 10:39 AM   #12
Tylercribbs's Avatar
Region: Arkansas
Highest octane i have is 89
Tylercribbs is offline   Reply With Quote
Old 05-15-2012, 11:57 AM   #13
if by "bad gas" you got 89 instead of 93 they make additives that can raise the octane up, but it wont be found in a little plastic thing as said above, those dont really work.
If its water or something else DRAIN IT asap and fill it back up with fresh gas.
Old 05-15-2012, 07:24 PM   #14
And after that use b12 gas treatment. Find it at walmart and plus don't get it on your paint.
Blackedout is offline   Reply With Quote
09:51 PM
