Help! 1st gear issue / 5th gear grinding - Mustang Evolution
Old 04-25-2012, 01:33 PM   #1
Missxalii's Avatar
Send a message via AIM to Missxalii
Hi, new to the forums as this is my first mustang. I have a 2010 V6 manual mustang. Bought it with 39k miles, it now has 46k. Mainly highway though. I'm having two problems.
Every once and a while I can't put the car into first. I've tried going from second to first, neutral to first, letting the clutch out in neutral then trying and nothing works.
Second issue is VERY often it grinds going into 5th. I've tried double clutching but that doesn't always help. The only thing I've noticed that does help SOMETIMES is if I hold the clutch in and very slowly shift into 5th. All my other gears are fine. My rear transmission seal is leaking, which I'm replacing next week. Fluid are always topped off, oils changed every 3k miles. I really don't beat on it.
Any ideas on what could be doing this? It's been going on since I got the car a few months ago. Thanks !
2012 Dub Edition V6 Mustang
full borla exhaust / steeda intake / 3.73's / aluminum driveshaft
exedy stage 3 clutch / spec steel flywheel / steeda shifter bushings
Missxalii is offline   Reply With Quote
Old 04-25-2012, 01:37 PM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Sounds like a 1-5 synchro to me
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-06-2012, 02:18 PM   #3
Re: Help! 1st gear issue / 5th gear grinding
Had similar issue going into 5th from 4th and 6th....4100 miles on 2012 GT Premium
Dealer dropped tranny and informed me that material defect on shift.....asked me if I rested my hand on shifter and informed me that even "slight" pressure on it can cause premature failure.
Man those Chinese must be using real cheap M.O.C.
Hinckley Bill is offline   Reply With Quote
07:15 PM
