Hid lights issue - Mustang Evolution
Old 05-14-2012, 07:50 PM   #1
Hid lights issue
I made sure when I did my hid lights that I did it right. However sometimes when I pull my headlights switch they don't come on I turn the the switch off and on again then they come one. Why does this happen?
Blackedout is offline   Reply With Quote
Old 05-14-2012, 07:57 PM   #2
Terminator's Avatar
I got myself a relay off eBay like 8 bucks fixed the same problem I had just search up Hid relay harness should make that problem go away
Terminator is offline   Reply With Quote
Old 05-15-2012, 10:37 AM   #3
Tylercribbs's Avatar
Region: Arkansas
I had no problem with my 30000k hids. Hook it up to the battery accessory and make sure you have a good ground. And hook the 9007 adapter up, and make sure your ballast can't get wet at all. My friend got water on his and one went out.
Tylercribbs is offline   Reply With Quote
Old 05-15-2012, 11:49 AM   #4
It's not me, it's you.
primer2tone's Avatar
+1 the relay kit keeps a constant power to the ballast eliminating spikes and drops in voltage that causes the ballast to fault.
Old 05-15-2012, 07:17 PM   #5
Timm04's Avatar
+1 agreed
Timm04 is offline   Reply With Quote
Old 05-19-2012, 10:10 PM   #6
Damn hid lights didn't come on... They arent wet, theres no loose connection everything's on right. I don't know what's wrong. They came on once but that was it
Old 05-19-2012, 10:56 PM   #7
Terminator's Avatar
Did you try using relays yet??
Old 05-19-2012, 11:09 PM   #8
Don't even know what that is
Old 05-20-2012, 01:43 AM   #9
Terminator's Avatar
Get HID relay from where ever you got your kit from its cheap and will fix that problem it fixed it for me.
Old 05-20-2012, 02:41 AM   #10
you dont need to shop for a realay in ebay they sell them for $5 bucks radio shak or autozone
---------- Post added at 03:41 AM ---------- Previous post was at 03:37 AM ----------
if they didnt come on no more after the first time then there probebly burn , get new ones and I have a diagram for you to use for your hids is very eazy to read and you only need two relays some cables ,connectors and two 10-15amp fuses
pepitochulo69 is offline   Reply With Quote
Old 05-20-2012, 11:01 AM   #11
Is this a reley?
Old 05-20-2012, 11:25 AM   #12
Las0mbra's Avatar
Is this a reley?
Yes.
Old 05-20-2012, 12:16 PM   #13
Lmao " slaps self in the face" dumbass
---------- Post added at 01:05 PM ---------- Previous post was at 01:04 PM ----------
Hope it isn't the ballast whatever things. Hope moisture or something small. Any ideas?
---------- Post added at 01:06 PM ---------- Previous post was at 01:05 PM ----------
How you tell if the light bulbs are good?
---------- Post added at 01:16 PM ---------- Previous post was at 01:06 PM ----------
I just think they might be done. They didn't turn on last night for a while. Then they came one, and now today they won't come on at all.
Old 05-20-2012, 02:39 PM   #14
Problem solved... Took the HID lights of the car. Went back to stock
Old 05-21-2012, 12:55 AM   #15
wish I could it fix them for you (15year/exp/installer)tell me you leave near los angeles , if so ill be gladly to help you
Old 05-25-2012, 07:12 PM   #16
lBRAlD's Avatar
Sounds like the capacitor in the ballast is weak or the bulbs are going bad
lBRAlD is offline   Reply With Quote
08:27 AM
