Exhaust 99 Cobra - Mustang Evolution
Old 05-17-2012, 07:06 AM   #1
lBRAlD's Avatar
Exhaust 99 Cobra
I had it in mind to keep it all factory but I can't take it anymore. I plan on getting some gears and cai. I have run flows with no cats back several years ago on a Dodge dakota r/t with no problems. I was looking for any kind of advice on doing this. I would really like some short headers as well. Also everyones po's on H pipe vs X pipe.
lBRAlD is offline   Reply With Quote
Old 05-17-2012, 07:11 AM   #2
I'm an x pipe person on 4v cars. Just make sure if you buy a catback system it specifies for 99-04 cobra only
Old 05-17-2012, 07:49 AM   #3
Re: Exhaust 99 Cobra
start with a catback, then if you want louder go with an X pipe or off road H etc.
I would look into Borla Stingers for your catback
Old 05-17-2012, 10:55 AM   #4
lBRAlD's Avatar
What do you think on removing the cats?
Old 05-17-2012, 11:32 AM   #5
It is against federal law to remove or tamper with your catalytic converters.
With that said take em out
Old 05-17-2012, 11:40 AM   #6
lBRAlD's Avatar
LOL I live in Alabama although its illegal we do not have any emissions test. I seen where had mil kits so that your cpu wouldn't know they were removed. I know some cars have to have a certain amount of back pressure to run right.
Old 05-17-2012, 12:38 PM   #7
my car would be to loud with no cats, but its all based on what you like.
Old 05-17-2012, 01:36 PM   #8
lBRAlD's Avatar
Do the x or h pipes come before or after the cats
---------- Post added at 02:36 PM ---------- Previous post was at 02:23 PM ----------
* that was a dumb question being that the cats are up front
Old 05-18-2012, 03:18 PM   #9
They are what the cats are mounted to. To be honest there isn't that much sound difference between high flow cats and no cats
Old 05-18-2012, 06:57 PM   #10
lBRAlD's Avatar
Is high flow what is stock?
Old 05-18-2012, 09:48 PM   #11
No, but most aftermarket companies offer them. I have a set with my 5 piece bassani unit, they look pretty on the shelf in the garage...
Old 05-18-2012, 09:57 PM   #12
lBRAlD's Avatar
Did you leave your cats off?
Old 05-19-2012, 12:22 PM   #13
Yupp. Ran them for a while but left them out last time I dropped the exhaust for a clutch job
Old 05-19-2012, 01:21 PM   #14
lBRAlD's Avatar
Have you had any issues with them out? Hate to be off subject but have you ever adjusted your clutch cable?
Old 05-19-2012, 01:39 PM   #15
No issues, none of our stangs have them. They are turned off in my tune and the other cars have mil eliminators.
On the clutch cable issue the stock adjustments suck. I have a fiore microclick firewall adjuster and steeda quadrant
Old 05-19-2012, 02:56 PM   #16
lBRAlD's Avatar
Cool. I thought it was me, I've not liked the clutch release since I got the car. I've had my first Stang for over 3 months now. Is that clutch cable a easy install?
Old 05-19-2012, 03:00 PM   #17
It's not a cable. The factory cable is by far the best piece. They aren't the easiest to install but not too difficult
Old 05-19-2012, 03:15 PM   #18
lBRAlD's Avatar
Is this where the the adj would go? Would it have any kind of adj now?
Old 05-19-2012, 03:48 PM   #19
That's where the firewall adjuster will install and there is no adjustability in the factory piece.
The only adjustment from the factory is to put your toes under the clutch pedal and pull back on it. You will probably hear it click a few times, but that us all the adjustment you can do
Old 05-19-2012, 03:55 PM   #20
lBRAlD's Avatar
Thanks
Old 05-19-2012, 04:45 PM   #21
lBRAlD's Avatar
Didn't hear a click but it made a huge difference, feels much better. I also noticed when I let off the clutch, sometimes it felt a little grabby. It doesn't now.
exhaust
03:24 PM
