Dash warning lights - Mustang Evolution
Old 05-23-2012, 10:06 PM   #1
Topthug98's Avatar
Dash warning lights
Has anyone know what the dash warning light with the wrench mean? It comes on and the power ony 2006 mustang some how looses power then I turn of the car and turn it back on and the light goes away and the horse power goes back to normal?
Topthug98 is offline   Reply With Quote
Old 05-27-2012, 06:58 PM   #2
Mezmer's Avatar
Re: Dash warning lights
Look it up in your owner's manual.
2004 Mustang Mach 1 - SY
Exhaust - Wanna be Flomasters...
JLT Ram Air Intake
SR Performance Short Throw Shifter
Mezmer is offline   Reply With Quote
Old 05-27-2012, 07:44 PM   #3
Blogger
99ford's Avatar
Ahh yes it is the infamous service engine light. You are probably throwing a code, if I had to guess the throttle pedal position sensor. But next time it happens idle the car and grab the code eventually it will still on.
Old 05-27-2012, 10:07 PM   #4
Topthug98's Avatar
So you have had that problem with the throttle position sensor? Has this been a common defect?
Old 05-28-2012, 06:18 PM   #5
Blogger
99ford's Avatar
Yes, and they issued a TSB about it, but when I went to the dealer under warranty they claimed nothing was wrong with it. I went in about 3 times, and 3 different dealers looked at me like I was crazy.
I ended up replacing the throttle position sensor after pulling the code and finding the TSB. It's not a hard job just follow the directions, and heat the TB up like the directions say.
Old 05-28-2012, 07:52 PM   #6
Topthug98's Avatar
Ok thanks for the info, I appreciate it
---------- Post added at 08:52 PM ---------- Previous post was at 08:46 PM ----------
Have you ever had any problems with the rear brake light bulbs keep going out?
Old 05-29-2012, 12:36 PM   #7
Blogger
99ford's Avatar
Not the brake light, but the rear turn signals went frequently. What I did to fix that problem was I cleaned that area really well with a damp cloth and water. I started by wiping the assembly's off, the metal behind them, and the rubber gaskets even the connectors (with a little cotton ball and rubbing alcohol). After everything dried I waxed the metal back there, took a q- tip with vaseline (not too much), and rubbed the gasket, and put a little on the bulb itself. It has helped the problem a little.
---------- Post added at 02:36 PM ---------- Previous post was at 02:33 PM ----------
I also put all new bulbs in when I did that. I just got fed up of one going out then the other. I just decided I would solve this problem once and for all!
Old 05-29-2012, 12:50 PM   #8
Topthug98's Avatar
Thanks good tips, I will definitely try it, I wonder if the sequential aftermarket harness has the same problem? It wouldn't be a bad investment if it solved it.
08:21 PM
