Stubborn Windshield Wipers - Mustang Evolution
Old 02-04-2008, 09:02 AM   #1
at7311's Avatar
Send a message via AIM to at7311
Since I've had the car, about 3 of 5 times I needed the wipers they didn't want to work. Twice this week I was in neutral and went to turn on the wipers before putting the car in gear. I would flip the switch to "slow" and nothing happened. So I would turn the switch all the way to "fast" just to see if maybe the time delay was goofed up, and nothing. Finally I said screw it and went about my business. Well, while driving I decided to try them again, still no show. I left it on slow to see how long it would take them to cut on. No longer than 5 min. they decided to work. There are times, like this morning, where I had no problem using them on demand.
Obviously this is either a switch or electrical quirk somewhere. Any ideas from the bullpen on what I should check? Has anyone else had this problem?
Thanks
at7311 is offline   Reply With Quote
Old 02-04-2008, 10:40 AM   #2
MonteCitan's Avatar
Re: Stubborn Windshield Wipers
Next time it acts up like this, try tapping on the wiper motor with a screwdriver/hammer, that's where I would start anyhow...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-07-2008, 12:56 PM   #3
Herbstang's Avatar
Check the fuse and replace it even if it looks good. Turn the windshield wipers on high or low , then pop the hood and locate the windshield wiper motor (it will be located on the firewall (drivers side). Grab a screwdriver, and with the handle end, moderately tap several times on the housing.
If the wipers move, you need a new motor. If it doesn't move, check voltage to the windshield wiper motor to insure power is getting to it. If it's not getting power you'll need to trace the lines from the wiper motor
Old 02-07-2008, 01:47 PM   #4
MonteCitan's Avatar
If the fuse is blown, the wipers won't work intermittently
Old 02-08-2008, 08:20 AM   #5
the wiper motor is under the cowl and is a major pain to get to. Its probably what the issue is unless the switch is going bad (which could also be the issue) and the switch isnt to bad to get to I dont think.
Old 02-08-2008, 08:26 AM   #6
Herbstang's Avatar
Never said it was blown Just suggested changing it cause you never know
Old 02-08-2008, 09:29 AM   #7
at7311's Avatar
K thanks a lot guys. I will try that next time it acts up.
2005 Mustang GT - Problem with Radio and Windshield Wipers Mr_Horsepower 2005-2010 Mustang GT 11 08-03-2017 12:57 PM
Windshield Decal v0nz General Mustang Discussion 10 07-30-2010 08:58 AM
Bosch Icon wipers Mustangfan2003 General Car Discussion 9 01-26-2008 03:33 AM
Windshield banner... crazeflier07 Mustang Audio & Video 3 04-02-2007 08:52 AM
windshield help a00v6stang Mustang Audio & Video 4 03-17-2007 12:35 PM
02:23 PM
